[fusion-trac] #74: invalid initial view in appdef causes javascript
error
Fusion
trac_fusion at osgeo.org
Wed Jun 4 14:23:03 EDT 2008
#74: invalid initial view in appdef causes javascript error
Reporter: pagameba | Owner: madair
Type: defect | Status: new
Priority: P1 | Milestone: 1.1
Component: Widgets | Version: 1.0.6
Severity: Major | Keywords:
External_id: | State: New
Browser: All | Os: All
If you set up an [wiki:ApplicationDefinition/MapSet/MapGroup#InitialView
InitialView] in a MapGroup and it is not valid (i.e. it is outside the
extent defined in a MapServer map file) then you will get a javascript
error in OpenLayers after the map loads.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/74>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
