[fusion-trac] #75: LoadMap performance issues
Fusion
trac_fusion at osgeo.org
Fri Jun 6 07:08:49 EDT 2008
Reporter: pagameba | Owner: madair
Type: enhancement | Status: new
Priority: P1 | Milestone: 2.0
Component: Core | Version: 1.0.6
Severity: Major | Keywords:
External_id: | State: New
Browser: All | Os: All
This affects both MapGuide and MapServer. Currently, LoadMap.php (as
called by loadMap and reloadMap) enumerates all the layers, scale ranges
and styles/classes to generate a full list of the structure of the Map.
But the Map widget only uses the layer list to manage layers, it is the
Legend widget that needs the extra information.
When you dynamically add or remove layers during a session, then, you need
to call reloadMap which processes the whole map again and returns all that
information to the client which again needs to parse it all. This is slow
and wasteful.
This enhancement is to refactor the code in LoadMap.php, the Map widgets,
the Legend widget and possibly the LayerManager widget to remove the scale
range/style/class code from LoadMap into a separate php script that can be
called from the Legend widget directly. This new script could cache scale
range information in the server-side session and other code that changes
the representation of the layer can then just remove the information from
the session to cause it to be rebuilt.
This will allow LoadMap to run faster and return a LOT less information to
the client, making initial load and reload faster.
The Legend widget will need to be refactored to get the layer list from
the Map (as it does now) and then make separate asynchronous requests to
the server to load up scale range/style/class information per layer. Then
on reload, it can make more intelligent choices to get only the
information that has changed.
The Legend widget should also be refactored to not rebuild itself on
reload but rather just restructure its existing tree if possible.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/75>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
