[fusion-trac] #146: Select radius causes map to pan
Fusion
trac_fusion at osgeo.org
Wed Nov 5 11:14:03 EST 2008
Reporter: chrisclaydon | Owner: pagameba
Type: defect | Status: assigned
Priority: P1 | Milestone: 2.0
Component: Widgets | Version: SVN
Severity: Major | Resolution:
Keywords: | External_id: 1150366
State: Analysing | Browser: All
Os: All |
Comment (by pagameba):
(In [1638]) Re #146. Move handling of the isExclusive attribute of
widgets into the setUiObj method of Widget so that two instances of the
same widget don't end up deactivating themselves (visually deactivating
the button) while leaving the widget active.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/146#comment:2>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
