[fusion-trac] #113: Can't zoom out beyond initial map view
Fusion
trac_fusion at osgeo.org
Thu Sep 11 15:21:53 EDT 2008
Reporter: andrewd | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone: 1.1
Component: Core | Version: SVN
Severity: Critical | Resolution:
Keywords: | External_id:
State: New | Browser: All
Os: All |
Comment (by madair):
I think I see what the problem is: in that Application definition there is
no <InitialView> element defined, it should look like so (for Sheboygan):
<MapSet xsi:type="MapSetType">
<MapGroup id="sheboygan" xsi:type="MapType">
<!-- should be centered on intersection of Lower Fallss Rd and S.Taylor
Dr. -->
<InitialView xsi:type="MapViewType">
<CenterX>-87.745061</CenterX>
<CenterY>43.740283</CenterY>
<Scale>8000</Scale>
</InitialView>
<Map xsi:type="MapGuideLayerType">
<Type>MapGuide</Type>
<SingleTile>true</SingleTile>
<Extension>
<ResourceId>Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition</ResourceId>
</Extension>
</Map>
</MapGroup>
- in ADSK Studio MapDefinition editor, the "initial view" box is really
the max extent for the map and these extents are set as the map extent
when the MapDefinition is loaded in Fusion from MapGuide.
- in the Studio FlexibleLayouts editor, there is a "use custom view"
option, filling this in sets an <InitialView> element in your AppDef, and
then you get the map initially zoomed in, but the MaxExtents remain as set
for the MapDefinition
You can also set the initial extent in the URL:
http://localhost:8008/mapguide/fusionOSGeo3/templates/mapguide/standard/?extent=-87.74740689295285,43.738716694573526,-87.74271510704716,43.74184930542647
Ticket URL: <http://trac.osgeo.org/fusion/ticket/113#comment:6>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
