[fusion-trac] #116: Legend.js: startGroup Initial value is
checked, wether or not set in Studio
Fusion
trac_fusion at osgeo.org
Mon Sep 15 14:54:10 EDT 2008
#116: Legend.js: startGroup Initial value is checked, wether or not set in Studio
Reporter: poulet1212 | Owner: madair
Type: defect | Status: assigned
Priority: P2 | Milestone: 1.1
Component: Widgets | Version: 1.0.6
Severity: Major | Resolution:
Keywords: | External_id:
State: Analysing | Browser: All
Os: All |
Comment (by poulet1212):
Absolutely right, it affects only the top-most group. I was not aware of
the specification, if you say the top-most group is the name of the map,
sure the visibility has to be set to true.
Actually, I understood that in another way, I have for top-most groups
many folders like:
-cadastral
-transportation
-etc...
Understanding what you say, I should do things like this:
-my_map_name
--cadastral
--transportation
--etc...
and then, the "problem" no longer occurs, because I can set visibility in
MGStudio for subfolders. I just mistook how to do the things in the right
way, I think we can close this ticket.
Rémy
Ticket URL: <http://trac.osgeo.org/fusion/ticket/116#comment:3>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
