[fusion-trac] #116: Legend.js: startGroup Initial value is checked, wether or not set in Studio
Fusion trac_fusion at osgeo.org
Mon Sep 15 14:59:30 EDT 2008
 Reporter:  poulet1212  |         Owner:  madair
     Type:  defect      |        Status:  assigned
 Priority:  P2          |     Milestone:  1.1
Component:  Widgets     |       Version:  1.0.6
 Severity:  Major       |    Resolution:
 Keywords:              |   External_id:
    State:  Analysing   |       Browser:  All
       Os:  All         |
Comment (by poulet1212):
 Once again, the formating above is not good, sorry.
 Absolutely right, it affects only the top-most group. I was not aware of
 the specification, if you say the top-most group is the name of the map,
 sure the visibility has to be set to true. Actually, I understood that in
 another way, I have for top-most groups many folders like:
 ->cadastral
 ->transportation
 ->etc...
 Understanding what you say, I should do things like this:
 ->my_map_name
 --->cadastral
 --->transportation
 --->etc...
 and then, the "problem" no longer occurs, because I can set visibility in
 MGStudio for subfolders. I just mistook how to do the things in the right
 way, I think we can close this ticket.
 Rémy
Ticket URL: <http://trac.osgeo.org/fusion/ticket/116#comment:4>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
