[fusion-trac] #271: MapGuide BasemapSwitcher Wigdet for commercial map services
Fusion trac_fusion at osgeo.org
Wed Jul 29 11:42:02 EDT 2009
 Reporter:  liuar        |         Owner:  liuar
     Type:  enhancement  |        Status:  closed
 Priority:  P2           |     Milestone:  Future
Component:  Widgets      |       Version:  2.0 - beta
 Severity:  Major        |    Resolution:  fixed
 Keywords:               |   External_id:
    State:  Review       |       Browser:  All
       Os:  All          |
Changes (by zjames):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Arthur, I tested your latest patch and it resolves the 'None' switching
 problem so I'm going to commit this to trunk. Thanks for your work on this
 enhancement.
 The map types aren't defined in this widget, as you pointed out, but
 making inclusion of a commercial layer the default does invoke code in
 generic.js that requires the service map variable to be available. That
 condition should probably be trapped in generic,js itself, however, so
 that will be a separate ticket.
 Committed in [1888]
Ticket URL: <http://trac.osgeo.org/fusion/ticket/271#comment:4>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
