[fusion-trac] #258: Redline widget display issue in IE8
Fusion
trac_fusion at osgeo.org
Fri May 22 01:50:52 EDT 2009
Reporter: christinebao | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone: Future
Component: Widgets | Version: 1.1.1
Severity: Major | Keywords:
External_id: 1223994 | State: New
Browser: All | Os: All
Fusion is at revision 1863.
MapGuide OS is at revision 3887.
XP (sp3) + IIS
Test in IE8.
1. Integrate FeatureInfo, Query, Theme and Redline widgets in standard
template's toolbar and task list. Please see the attached
ApplicationDefinition.xml.
2. Open index.html of Standard template, local URL:
http://localhost/mapguide2010/fusion/templates/mapguide/standard/index.html
3. Redline widget's html display in new window when opening index.html
4. In toolbar click FeatureInfo, Query, Theme and Redline to switch
between them. After click Redline button the task pane can't display
Redline's page.
5. Switch them in task list and works.
Summary:
1. The Redline's page should not display when opening index.html
2. In toolbar should be able to switch to Redline.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/258>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
