[fusion-trac] #259: Theme widget's color picker not work in IE8
Fusion trac_fusion at osgeo.org
Fri May 22 01:58:49 EDT 2009
   Reporter:  christinebao  |       Owner:  madair
       Type:  defect        |      Status:  new
   Priority:  P2            |   Milestone:  Future
  Component:  Widgets       |     Version:  1.1.1
   Severity:  Major         |    Keywords:
External_id:  1224000       |       State:  New
    Browser:  All           |          Os:  All
 Fusion is at revision 1863.
 MapGuide OS is at revision 3887.
 XP (sp3) + IIS
 Test in IE8.
 1. Integrate Theme widget into standard template's toolbar and task list.
 Please see the attached ApplicationDefinition.xml.
 2. Open theme widget.
 3. Click the 4 color picker.
 Result:
 The "Fill Color" From (default is red) works, but other three don't work.
 There is a new window pops up but blank.
 Expected:
 All of the four color picker should work.
 Note:
 It works on Firefox 3, but not in IE8.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/259>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
