[fusion-trac] #260: Can't select feature in MG map,
error dialog pops up
Fusion
trac_fusion at osgeo.org
Mon May 25 23:11:01 EDT 2009
#260: Can't select feature in MG map, error dialog pops up
Reporter: christinebao | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone: Future
Component: MapGuide | Version: 1.1.1
Severity: Blocker | Keywords:
External_id: 1224520 | State: New
Browser: All | Os: All
Fusion is at revision 1863. MapGuide OS is at revision 3894.
Steps to reproduce:
1. Load Sheboygan.mgp.
2. Create a flexible weblayout, use
Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition as MapDefinition,
choose Slate template by default.
3. Open the webpage, choose "Select" in context menu, and click to select
a feature.
Result:
An error dialog pops up, and nothing selected.
Test Environment:
1. XP(SP3) + IIS
2. IE8 has this problem
3. Firefox3.0.10 has this problem.
4. Safari 3.2.3 has this problem.
5. Google chrome 1.0.154.65 has this problem.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/260>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
