[fusion-trac] #333: Bing: Map with Bing maps doesn't refresh
when browser maximize
Fusion
trac_fusion at osgeo.org
Thu Apr 15 13:11:57 EDT 2010
#333: Bing: Map with Bing maps doesn't refresh when browser maximize
Reporter: jennyhe | Owner: madair
Type: defect | Status: reopened
Priority: P2 | Milestone: 2.1
Component: Widgets | Version: 1.1.1
Severity: Major | Resolution:
Keywords: | External_id: 1279971
State: New | Browser: All
Os: All |
Comment (by chrisclaydon):
I've added !OpenLayersPatch2.patch. This resolves the problem where other
layers do not resize correctly when the base layer is a Bing map.
The cause of the problem is that after VEMap.Resize() has been called on
the Bing layer, it still takes a while before this layer adjusts to the
change. In the meantime, the other non-base layers try to resize too, but
their offsets are calculated incorrectly, because they rely on the base
layer to calculate the pixel offset of their top-left corner in mapping
coordinates.
The patch adds an event handler to redraw all the non-base layers when the
VEMap object has actually finished resizing, and is thus able to return
the correct pixel offsets.
I will be making this change to the adsk/2.2gp sandbox. Please review and
let me know if it should go into trunk.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/333#comment:6>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
