[fusion-trac] #393: Exception in FDO component when using
feature information (Digitize Polygon)
Fusion
trac_fusion at osgeo.org
Tue Apr 20 06:08:04 EDT 2010
#393: Exception in FDO component when using feature information (Digitize
Polygon)
Reporter: liuar | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone: Future
Component: Widgets | Version: 1.1.1
Severity: Major | Resolution:
Keywords: | External_id: 1313209
State: New | Browser: All
Os: All |
Comment (by liuar):
This defect occus on oracle and sql spatial providers.[[BR]]
[[BR]]
The reason of the defect is in featureinfomain.php,
fuction OnPolyonDigitized(polygon)[[BR]]
in this function, the digitized geometry will be set as geometry fiter but
the geometry text which describes the polygon is not a valid polygon,
because the polygon is not closed.[[BR]]
function OnPolyonDigitized(polygon) {
var points = [];
for (var i = 0; i < polygon.Count; i++) {
points.push(polygon.Point(i).X+' '+polygon.Point(i).Y);
var geomText = 'POLYGON(('+points.join(',')+'))';
SetSpatialFilter(geomText);
[[BR]]
to fix this defect we just need to make the geometry text close[[BR]]
var points = [];
var geomText = 'POLYGON(('+points.join(',')+ ','+
polygon.Point(0).X +' '+ polygon.Point(0).Y +'))';
Ticket URL: <http://trac.osgeo.org/fusion/ticket/393#comment:1>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
