[fusion-trac] #312: decode xml string before rendering
attribute in www\fusion\widgets\SelectionPanel.js
Fusion
trac_fusion at osgeo.org
Mon Aug 16 10:17:22 EDT 2010
#312: decode xml string before rendering attribute in
Reporter: poulet1212 | Owner: madair
Type: defect | Status: closed
Priority: P2 | Milestone: 2.2
Component: Widgets | Version: 1.1.1
Severity: Major | Resolution: wontfix
Keywords: | External_id:
State: New | Browser: All
Os: All |
Changes (by madair):
* status: assigned => closed
* resolution: => wontfix
Comment:
closing the issue as suggested. If you can provide a data set which
exhibits the behaviour (i.e. with markup in the property values), feel
free to re-open the ticket and attach the data.
(As a side note, markup in the attribute labels are correctly decoded and
displayed)
Ticket URL: <http://trac.osgeo.org/fusion/ticket/312#comment:5>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
