[fusion-users] Overview Map embedded in map (Google-like)
Fred warnock
fred.warnock at gmail.com
Fri Aug 8 10:49:44 EDT 2008
Hi Tim,
As you have suggested it is just a matter of applying the right CSS to
the DIV you created.
something like the following will put it in the bottom right corner of
the map:
#OverviewMap {
display: block;
position: absolute;
width: 100px;
height: 100px;
z-index: 1001;
bottom: 0px;
right: 0px;
Make sure you set the z-index high enough to get on top of the open
layers map, and also make sure you put a z-index on the map container
because FF3 is now quite picky about how the z-index stacks work.
Fred
Nolte, Tim wrote:
> I was wondering if there is a built-in way to embed the Overview Map
> inside the Map window either like Google Maps has it or as a floating
> window like in MGOS/Fusion? I have moved it from the Panels layout and
> added an 'OverviewMap' div inside my 'Map' div and I can see it in there
> in a weird way so I supposed it could be just a matter of applying the
> right CSS to get something close to what I want. Anyone doing something
> like this already?
> - Tim
> Timothy J Nolte - tnolte at ilpcs.com
> Network Planning Engineer
> iPCS Wireless, Inc.
> 4717 Broadmoor Ave, Suite G
> Kentwood, MI 49512
> Office: 616-656-5163
> PCS: 616-706-2438
> Fax: 616-554-6484
> Web: www.ipcswirelessinc.com
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
More information about the fusion-users
