[fusion-users] Overview Map embedded in map (Google-like)
Tómas Guðmundsson tomas at snertill.is
Mon Aug 11 10:37:31 EDT 2008
Without going in to too much detail I would suggest you would do it with minimize/restore functionality in mind instead of hide/show. That is maybe what you meant I'm not sure. Just like google does it. But you could design a little "toolbar" right on top of the minimap and then just a hide feature, which then switches it to a minimized image or text that says Minimap or something? For that sweet sliding function you'll have to talk to Jx. but I am not familiar with it enough to say how it's done. But I think it's possible, at least scriptaculous and prototype both have that functionality and I think it is based off that.
Regards,
Tómas.
-----Original Message-----
From: Nolte, Tim [mailto:Tim.Nolte at ipcswirelessinc.com]
Sent: 11. ágúst 2008 14:22
To: Tómas Guðmundsson; Fred warnock
Cc: fusion-users at lists.osgeo.org
Subject: RE: [fusion-users] Overview Map embedded in map (Google-like)
Actually, what I'm hoping to do it include some kind of control right inside the embedded map. I've attached an example of what I have currently. I'm wondering if anyone knows if there is anything in the JX library that could help me add some type of image that would act as the show/hide? I know that OpenLayers has something like this built-in for it's overview map.
- Tim
Timothy J Nolte - tnolte at ilpcs.com
Network Planning Engineer
iPCS Wireless, Inc.
4717 Broadmoor Ave, Suite G
Kentwood, MI 49512
Office: 616-656-5163
PCS:    616-706-2438
Fax:    616-554-6484
Web: www.ipcswirelessinc.com
From: Tómas Guðmundsson [mailto:tomas at snertill.is]
Sent: Monday, August 11, 2008 10:12 AM
To: Nolte, Tim; Fred warnock
Tim,
You can easily create a new widget that inherits from Widget and ButtonBase and then stamp it on to the menubar. But you can also modify a Boolean value into the "ShowOverviewMap" widget so that it keeps track on its state.
bShown ? hide() : show(); // I think :)
Just one line it ;)
Regards,
Tómas.
From: fusion-users-bounces at lists.osgeo.org [mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of Nolte, Tim
Sent: 11. ágúst 2008 13:57
To: Fred warnock
Fred,
Thanks, actually I was impatient so just decided to go the CSS route. I actually did get a pretty good embedded Google style overview map. Only thing now I'm trying to accomplish is some sort of show/hide button for it.
- Tim
iPCS Wireless, Inc.
Kentwood, MI 49512
PCS:    616-706-2438
Fax:    616-554-6484
> From: Fred warnock [mailto:fred.warnock at gmail.com]
> Sent: Friday, August 08, 2008 10:50 AM
> To: Nolte, Tim
> Subject: Re: [fusion-users] Overview Map embedded in map (Google-like)
> Hi Tim,
> As you have suggested it is just a matter of applying the right CSS to
> the DIV you created.
> something like the following will put it in the bottom right corner of
> the map:
> #OverviewMap {
>    display: block;
>    position: absolute;
>    width: 100px;
>    height: 100px;
>    z-index: 1001;
>    bottom: 0px;
>    right: 0px;
> Make sure you set the z-index high enough to get on top of the open
> layers map, and also make sure you put a z-index on the map container
> because FF3 is now quite picky about how the z-index stacks work.
> Fred
> Nolte, Tim wrote:
> > I was wondering if there is a built-in way to embed the Overview Map
> > inside the Map window either like Google Maps has it or as
> a floating
> > window like in MGOS/Fusion? I have moved it from the Panels
> layout and
> > added an 'OverviewMap' div inside my 'Map' div and I can
> see it in there
> > in a weird way so I supposed it could be just a matter of
> applying the
> > right CSS to get something close to what I want. Anyone
> doing something
> > like this already?
> > - Tim
> > iPCS Wireless, Inc.
> > Kentwood, MI 49512
> > PCS:    616-706-2438
> > Fax:    616-554-6484
> > fusion-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/fusion-users
More information about the fusion-users mailing list
