[fusion-users] HTML in selection results?
Jason Birch
Jason.Birch at nanaimo.ca
Fri Aug 15 11:06:18 EDT 2008
Paul wrote:
> alter table properties add column PropertyReport;
> update properties set PropertyReport = ...
Heh.
To Fusion (or MapGuide for that matter), these calculated columns look
no different than a regular data source; it just creates a new feature
class that can be addressed instead of the default feature class.
Basically the same as Alter Table or Create View. For clarity, I should
have just left that part out of my question :)
I can see a selection rendering plugin solving this problem though, as
long as it allows you to choose columns not to display. For instance, I
might not want to show the property ID in the selection attribute list,
but use it to create links to the two reports.
Is there the equivalent of html_entity_decode in JavaScript?
I'm just glad that the maptips code allows me to include HTML... please
don't change this ;)
Jason
More information about the fusion-users
