[fusion-users] Jx.Layout and CSS positioning best practice
Paul Spencer
pspencer at dmsolutions.ca
Mon Aug 18 08:52:55 EDT 2008
right, resize is a method added by Jx.Layout that causes the size of
an element to be recalculated - you can safely remove that if you are
not using Jx.Layout.
Cheers
Paul
On 18-Aug-08, at 4:41 AM, gingerbbm wrote:
> Hi Paul
> pagameba wrote:
>> you can remove the Jx.Layout part and just set the size of your div
>> using
>> CSS
> Thanks for your reply, but it seems that if I remove the Jx.Layout()
> call
> then I don't have a handle on the map, so I have to remove the
> map.resize()
> call in my window onload() event, and once that is removed the map
> doesn't
> load.
> I guess I'm missing something ;)
> Thanks
> Stuart
> View this message in context: http://www.nabble.com/Jx.Layout-and-CSS-positioning-best-practice-tp18977839p19027748.html
> Sent from the Fusion Users mailing list archive at Nabble.com.
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
Paul Spencer
Chief Technology Officer
DM Solutions Group Inc
http://www.dmsolutions.ca/
More information about the fusion-users
