[fusion-users] Jx.Layout and CSS positioning best practice
gingerbbm stuart.jones at jacobs.com
Mon Aug 18 04:41:53 EDT 2008
Hi Paul
pagameba wrote:
> you can remove the Jx.Layout part and just set the size of your div using
> CSS
Thanks for your reply, but it seems that if I remove the Jx.Layout() call
then I don't have a handle on the map, so I have to remove the map.resize()
call in my window onload() event, and once that is removed the map doesn't
load.
I guess I'm missing something ;)
Thanks
Stuart
View this message in context: http://www.nabble.com/Jx.Layout-and-CSS-positioning-best-practice-tp18977839p19027748.html
Sent from the Fusion Users mailing list archive at Nabble.com.
More information about the fusion-users mailing list
