[fusion-users] Nested splitter in fusion
Paul Spencer
pspencer at dmsolutions.ca
Wed Aug 27 17:09:54 EDT 2008
Rodolfo,
(you need to subscribe to the list to be able to post)
You can nest splitters:
var s1 = new Jx.Splitter('myDiv', {splitInto:2});
var s2 = new Jx.Splitter(s1.elements[1], {splitInto:
2,layout:'vertical'});
this probably isn't what you want exactly, but it gives you the syntax
to create a second splitter inside on of the areas of the first
splitter.
Cheers
Paul
On 27-Aug-08, at 4:53 PM, Rodolfo Moreno wrote:
> Hi all, the last week I wrote in mapguide forum about this (no body
> has
> answered).
> I hope that somebody has a solution or workaround about it.
> Here is the message that I sent:
> I am making a new flexible layout (as of the slate template)
> My first altenative is using nested splitters (for me is the better):
> splitter1 (horizontal): map , sidebar
> splitter2 (vertical): splitter1, taskpane
> I was tried with no success.
> Is it possible? if the answer is NO then My second alternative is:
> and in the bottom Taskpane
> I got it the second alternative, but with an issue.
> The layout is OK on the first time that the layout is loaded, but if
> the
> user changes the size of the window(browser), then all the widgets are
> changed of size automatically except the taskpane on the bottom.
> finally the
> taskpane on the bottom overlays to the map or disappears.
> How could I fix this issue?
> I found this link posted by PAUL SPENCER:
> http://mapmobility.dmsolutions.ca/jx/docs/NaturalDocs/files/splitter/jxsplitter-js.html
> but there are no samples.
> Best regards and thanks in advance.
> Rodolfo Moreno
> CivilEng
> View this message in context: http://n2.nabble.com/Nested-splitter-in-fusion-tp788041p788041.html
> Sent from the Fusion Users mailing list archive at Nabble.com.
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
Paul Spencer
Chief Technology Officer
DM Solutions Group Inc
http://www.dmsolutions.ca/
More information about the fusion-users
