[fusion-users] Nested splitter in fusion
Rodolfo Moreno rmoreno at voxiva.com
Thu Aug 28 20:23:39 EDT 2008
Thanks indeed Paul,
Finally I could make the nested splitters.
sorry about my suscription, I forgot to do it, but I already have get
suscribe me today.
Paul Spencer-2 wrote:
> Rodolfo,
> (you need to subscribe to the list to be able to post)
> You can nest splitters:
> var s1 = new Jx.Splitter('myDiv', {splitInto:2});
> var s2 = new Jx.Splitter(s1.elements[1], {splitInto:
> 2,layout:'vertical'});
> this probably isn't what you want exactly, but it gives you the syntax
> to create a second splitter inside on of the areas of the first
> splitter.
> Cheers
> Paul
> On 27-Aug-08, at 4:53 PM, Rodolfo Moreno wrote:
>> Hi all, the last week I wrote in mapguide forum about this (no body
>> has
>> answered).
>> I hope that somebody has a solution or workaround about it.
>> Here is the message that I sent:
>> I am making a new flexible layout (as of the slate template)
>> My first altenative is using nested splitters (for me is the better):
>> splitter1 (horizontal): map , sidebar
>> splitter2 (vertical): splitter1, taskpane
>> I was tried with no success.
>> Is it possible? if the answer is NO then My second alternative is:
>> and in the bottom Taskpane
>> I got it the second alternative, but with an issue.
>> The layout is OK on the first time that the layout is loaded, but if
>> the
>> user changes the size of the window(browser), then all the widgets are
>> changed of size automatically except the taskpane on the bottom.
>> finally the
>> taskpane on the bottom overlays to the map or disappears.
>> How could I fix this issue?
>> I found this link posted by PAUL SPENCER:
>> http://mapmobility.dmsolutions.ca/jx/docs/NaturalDocs/files/splitter/jxsplitter-js.html
>> but there are no samples.
>> Best regards and thanks in advance.
>> Rodolfo Moreno
>> CivilEng
>> View this message in context:
>> http://n2.nabble.com/Nested-splitter-in-fusion-tp788041p788041.html
>> Sent from the Fusion Users mailing list archive at Nabble.com.
>> fusion-users mailing list
>> fusion-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/fusion-users
>     Paul Spencer
>     Chief Technology Officer
>     DM Solutions Group Inc
>     http://www.dmsolutions.ca/
Rodolfo Moreno
CivilEng
View this message in context: http://n2.nabble.com/Nested-splitter-in-fusion-tp788041p791090.html
More information about the fusion-users mailing list
