[fusion-users] MapServer/Fusion/Select Tool
Paul Deschamps
pdeschamps at dmsolutions.ca
Thu Aug 28 10:23:02 EDT 2008
In firebug you will see a call in the "Net" section that loads the mapserver
cgi. Open that link up in a new tab and save the images before and after a
selection.
If both images look good then you are correct in saying it has something to
do with fusion or your application code otherwise it's a mapserver issue.
Cheers
Paul D.
On Thu, Aug 28, 2008 at 12:53 AM, Nolte, Tim
<Tim.Nolte at ipcswirelessinc.com>wrote:
> Wrong also, I'm already using AGG/jpeg for my map output.
> - Tim
> Timothy J Nolte - tnolte at ilpcs.com
> Network Planning Engineer
> iPCS Wireless, Inc.
> 4717 Broadmoor Ave, Suite G
> Kentwood, MI 49512
> Office: 616-656-5163
> PCS: 616-706-2438
> Fax: 616-554-6484
> Web: www.ipcswirelessinc.com
> -----Original Message-----
> From: fusion-users-bounces at lists.osgeo.org on behalf of Paul Deschamps
> Sent: Wed 8/27/2008 5:38 PM
> To: Nolte, Tim
> Cc: fusion-users at lists.osgeo.org
> Subject: Re: [fusion-users] MapServer/Fusion/Select Tool
> Another possibility is that you are using a palleted image for your
> IMAGETYPE.
> GD does a real nice job on certain things however for a real quality image
> AGG is awesome
> Set your image type to aggjpeg and add this output format block.
> This is more of a "mapserver" question then a "fusion" question.
> IMAGETYPE aggjpeg
> OUTPUTFORMAT
> NAME "aggjpeg"
> DRIVER "AGG/JPEG"
> FORMATOPTION "QUALITY=100"
> IMAGEMODE "RGB"
> END
> Cheers
> Paul D.
> On Wed, Aug 27, 2008 at 2:47 PM, Nolte, Tim
> > I'm wondering if anyone else has experienced and issue with Fusion
> > returning a distorted map after doing a selection? Attached are examples
> > of what I mean.
> > MapServer 5.2
> > Fusion 1.0.6
> > Thanks.
> > - Tim
> > iPCS Wireless, Inc.
> > Kentwood, MI 49512
> > PCS: 616-706-2438
> > Fax: 616-554-6484
> > fusion-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/fusion-users
URL: http://lists.osgeo.org/pipermail/fusion-users/attachments/20080828/8f603691/attachment.html
More information about the fusion-users
