[fusion-users] MapServer/Fusion/Select Tool
Nolte, Tim
Tim.Nolte at ipcswirelessinc.com
Thu Aug 28 11:31:33 EDT 2008
Paul,
Good idea using Firebug to check the output results. It is a problem
with Fusion. Both images looked just fine in Firebug. I'll have to do
some digging and see if I can find the bug in Fusion.
- Tim
Timothy J Nolte - tnolte at ilpcs.com
Network Planning Engineer
iPCS Wireless, Inc.
4717 Broadmoor Ave, Suite G
Kentwood, MI 49512
Office: 616-656-5163
PCS: 616-706-2438
Fax: 616-554-6484
Web: www.ipcswirelessinc.com
-----Original Message-----
From: pdescham49 at gmail.com [mailto:pdescham49 at gmail.com] On Behalf Of
Paul Deschamps
Sent: Thursday, August 28, 2008 10:23 AM
To: Nolte, Tim
Cc: fusion-users at lists.osgeo.org
Subject: Re: [fusion-users] MapServer/Fusion/Select Tool
In firebug you will see a call in the "Net" section that loads the
mapserver cgi. Open that link up in a new tab and save the images before
and after a selection.
If both images look good then you are correct in saying it has something
to do with fusion or your application code otherwise it's a mapserver
issue.
Cheers
Paul D.
On Thu, Aug 28, 2008 at 12:53 AM, Nolte, Tim
<Tim.Nolte at ipcswirelessinc.com> wrote:
Wrong also, I'm already using AGG/jpeg for my map output.
- Tim
iPCS Wireless, Inc.
Kentwood, MI 49512
PCS: 616-706-2438
Fax: 616-554-6484
From: fusion-users-bounces at lists.osgeo.org on behalf of Paul
Deschamps
Sent: Wed 8/27/2008 5:38 PM
To: Nolte, Tim
Another possibility is that you are using a palleted image for
your
IMAGETYPE.
GD does a real nice job on certain things however for a real
quality image
AGG is awesome
Set your image type to aggjpeg and add this output format block.
This is more of a "mapserver" question then a "fusion" question.
IMAGETYPE aggjpeg
OUTPUTFORMAT
NAME "aggjpeg"
DRIVER "AGG/JPEG"
FORMATOPTION "QUALITY=100"
IMAGEMODE "RGB"
END
Cheers
Paul D.
On Wed, Aug 27, 2008 at 2:47 PM, Nolte, Tim
<Tim.Nolte at ipcswirelessinc.com>wrote:
> I'm wondering if anyone else has experienced and issue with
Fusion
> returning a distorted map after doing a selection? Attached
are examples
> of what I mean.
> MapServer 5.2
> Fusion 1.0.6
> Thanks.
> - Tim
> iPCS Wireless, Inc.
> Kentwood, MI 49512
> PCS: 616-706-2438
> Fax: 616-554-6484
> fusion-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fusion-users
More information about the fusion-users
