[fusion-users] MapServer/Fusion/Select Tool
Khalid kmsaif at yahoo.com
Thu Aug 28 22:57:12 EDT 2008
I am having the same problem. I am not sure whatelse to check?. Suggestions are welcome.
Thanks
Khalid
--- On Thu, 8/28/08, Nolte, Tim <Tim.Nolte at ipcswirelessinc.com> wrote:
From: Nolte, Tim <Tim.Nolte at ipcswirelessinc.com>
Subject: RE: [fusion-users] MapServer/Fusion/Select Tool
To: "Paul Deschamps" <pdeschamps at dmsolutions.ca>
Cc: fusion-users at lists.osgeo.org
Date: Thursday, August 28, 2008, 8:31 PM
Paul,
Good idea using Firebug to check the output results. It is a problem
with Fusion. Both images looked just fine in Firebug. I'll have to do
some digging and see if I can find the bug in Fusion.
- Tim
Timothy J Nolte - tnolte at ilpcs.com
Network Planning Engineer
iPCS Wireless, Inc.
4717 Broadmoor Ave, Suite G
Kentwood, MI 49512
Office: 616-656-5163
PCS:    616-706-2438
Fax:    616-554-6484
Web: www.ipcswirelessinc.com
-----Original Message-----
From: pdescham49 at gmail.com [mailto:pdescham49 at gmail.com] On Behalf Of
Paul Deschamps
Sent: Thursday, August 28, 2008 10:23 AM
To: Nolte, Tim
Subject: Re: [fusion-users] MapServer/Fusion/Select Tool
In firebug you will see a call in the "Net" section that loads the
mapserver cgi. Open that link up in a new tab and save the images before
and after a selection.
If both images look good then you are correct in saying it has something
to do with fusion or your application code otherwise it's a mapserver
issue.
Cheers
Paul D.
On Thu, Aug 28, 2008 at 12:53 AM, Nolte, Tim
	Wrong also, I'm already using AGG/jpeg for my map output.
	- Tim
	iPCS Wireless, Inc.
	Kentwood, MI 49512
	PCS: 616-706-2438
	Fax: 616-554-6484
	From: fusion-users-bounces at lists.osgeo.org on behalf of Paul
Deschamps
	Sent: Wed 8/27/2008 5:38 PM
	To: Nolte, Tim
	Another possibility is that you are using a palleted image for
your
	IMAGETYPE.
	GD does a real nice job on certain things however for a real
quality image
	AGG is awesome
	Set your image type to aggjpeg and add this output format block.
	This is more of a "mapserver" question then a "fusion"
question.
	IMAGETYPE aggjpeg
	  OUTPUTFORMAT
	    NAME "aggjpeg"
	    DRIVER "AGG/JPEG"
	    FORMATOPTION "QUALITY=100"
	    IMAGEMODE "RGB"
	  END
	Cheers
	Paul D.
	On Wed, Aug 27, 2008 at 2:47 PM, Nolte, Tim
	<Tim.Nolte at ipcswirelessinc.com>wrote:
	> I'm wondering if anyone else has experienced and issue with
Fusion
	> returning a distorted map after doing a selection? Attached
are examples
	> of what I mean.
	> MapServer 5.2
	> Fusion 1.0.6
	> Thanks.
	> - Tim
	> iPCS Wireless, Inc.
	> Kentwood, MI 49512
	> PCS:    616-706-2438
	> Fax:    616-554-6484
	> fusion-users mailing list
	> http://lists.osgeo.org/mailman/listinfo/fusion-users
URL: http://lists.osgeo.org/pipermail/fusion-users/attachments/20080828/67c5c100/attachment.html
More information about the fusion-users mailing list
