[fusion-users] Ajax callback error without any reason.
Tómas Guðmundsson tomas at snertill.is
Mon Jul 7 08:59:19 EDT 2008
Hi Paul,
You know, I'm not sure that's the thing. I have witnessed these errors appear before the LoadMap.php is posted. Now the thing is I also have tried using a backup of my files that are week old. Reverting any modification to a state where everything was working but still no luck. This is line 219 of LoadMap.php just to be sure.
$filterText = $filter->length==1? $filter->item(0)->nodeValue: "";
And to clear things up here is how the error looks in the console with line breaks.
Fusion Error:
WARNING: Error occurred in an AJAX callback.
SyntaxError: invalid label
File: undefined (219)
xx)
So File is not the invalid label, but the File that the error occurred in is undefined. I have also searched through every single file for the error message "invalid label" and I couldn't find it. Which is very strange. I have found stuff like, extents not valid or something like that but not invalid label. The only thing that matched "SyntaxError" was in some narcissum selenium javascript files and I have no idea what that is.
Regards,
Tómas.
-----Original Message-----
From: Paul Spencer [mailto:pspencer at dmsolutions.ca]
Sent: 7. júlí 2008 11:59
To: Tómas Guðmundsson
Cc: fusion-users at lists.osgeo.org
Subject: Re: [fusion-users] Ajax callback error without any reason.
Hi Tómas,
the error is coming from LoadMap.php (first line), it looks as if you
have modified this file around line 219 and introduced a syntax error
(hint: look for 'File:').
Cheers
Paul
On 7-Jul-08, at 4:47 AM, Tómas Guðmundsson wrote:
> Hi all.
> As I was developing fusion just before the weekend I recieve one of
> errors I've had before but I can't seem to fix it. I thought it was
> something I did but I've made sure that it isn't. I did that by
> rolling back in our subversion system to a earlier revision /
> version. And even to a point where everything was fine and working a
> long time ago.
> So now I'm curious if somebody knows what this error means. This
> error system / handling could be improved by actually telling what
> file is doing it wrong. If somebody could point me in a good
> direction where to break, that would be great as well.
> Console.log =
> POST http://localhost:8008/mapguide2009/fusion/MapGuide/php/LoadMap.php
>  jx_combined.js (line 876)
> Fusion Error: WARNING: Error occurred in an AJAX callback.
> SyntaxError: invalid label File: undefined (219) xx)
> This is the cause of me not being able to see my map.
> Thanks for your help.
> Regards,
> Tómas.
> fusion-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fusion-users
    Paul Spencer
    Chief Technology Officer
    DM Solutions Group Inc
    http://www.dmsolutions.ca/
More information about the fusion-users mailing list
