[fusion-users] MapServer + Fusion
Nolte, Tim Tim.Nolte at ipcswirelessinc.com
Fri Jul 11 12:37:41 EDT 2008
One issue that I have, and I found out why, is that my separate layers
end up getting stuck together. (those that are in the same group). What
I found out was that those layers that I have named like "Johnson City"
aren't accessed correctly and able to be independently turned off.
However, if I name the layer "JohnsonCity" with no spaces in the name
then it works fine. The things about this is that what gets displayed in
the Legend is that name and I don't want crapping looking layer titles.
Also, something that I haven't figured out is how to completely hide
certain layers from the legend that I use for dynamic purposes, that
shouldn't be showing by default. Another problem I seem to have is that
my legend icons don't all seem to be showing up correctly. Now this
could be an issue with the version of UMN MapServer that I'm using. I
did have to do some custom things to get these working in my other
mapping framework.
- Tim
Timothy J Nolte - tnolte at ilpcs.com
Network Planning Engineer
iPCS Wireless, Inc.
4717 Broadmoor Ave, Suite G
Kentwood, MI 49512
Office: 616-656-5163
PCS:    616-706-2438
Fax:    616-554-6484
Web: www.ipcswirelessinc.com
> -----Original Message-----
> From: fusion-users-bounces at lists.osgeo.org
> [mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of
> Jason Fournier
> Sent: Friday, July 11, 2008 10:08 AM
> To: fusion-users at lists.osgeo.org
> Subject: RE: [fusion-users] MapServer + Fusion
> Hi Tim,
> >From my understanding you should not have to do too much
> tweaking of your
> MapFile to get it to work properly with Fusion.  Certain widgets will
> require certain aspects of the MapFile to be present but you
> should be able
> to get a usable map without having to populate the MapFile
> with extraneous
> information.  What specifically are some of the issues you
> are witnessing?
> Jason
> [mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of Nolte, Tim
> Sent: Thursday, July 10, 2008 3:29 PM
> Subject: [fusion-users] MapServer + Fusion
> So was able to get something working by using files found under
> fusion->templates->mapserver->standard for me use as samples.
> I was able
> to get the gmap demo data working and even my own current Production
> MapServer .map file. There are a lot of strange issues that
> make it seem
> as though I'm going to need to make a new .map file that is tuned for
> Fusion. I'm going to have to do some reading. Off hand, does
> anyone have
> any pointers? I'm thinking that I'm going to have to add a
> bunch of meta
> data for this to work correctly. Is Fusion using my MapServer
> install/mapfile as a WMS or WFS source?
> - Tim
> iPCS Wireless, Inc.
> Kentwood, MI 49512
> PCS:    616-706-2438
> Fax:    616-554-6484
> fusion-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fusion-users
More information about the fusion-users mailing list
