[fusion-users] MapServer + Fusion
Paul Spencer pspencer at dmsolutions.ca
Fri Jul 11 14:04:26 EDT 2008
Tim,
there is a little bit of layer metadata that you can use to control
how things appear in the legend.
"displayInLegend" "true|false"
By default, all layers are shown in the legend.  If set to false, it
will hide the layer in the legend
"expandInLegend" "true|false"
By default, all classified layers will show a sub-branch in the legend
with all the classes.  If set to false then the sub-branch is
initially collapsed
"legendLabel" "string value"
By default, the layer's NAME value is used in the legend.  If this
metadata is set, then the value will be used in the legend instead.
"selectable" "true|false"
By default, layers are not 'selectable' using the select widget.  If
this is set to 'true' then the layer will be considered 'selectable'
so the select widget will be enabled when this layer is selected in
the legend.
The legend will create folders for each group and put the appropriate
layers in those groups.  The groups respond to the following metadata
in the first LAYER object in the group (first layer to use the group
name)
"groupLegendLabel" "string value"
By default, the group name is used as the legend label.  If this
metadata is set then the value will be used instead of the group name.
"groupDisplayInLegend" "true|false"
By default, all groups are displayed in the legend.  Setting this to
false will hide the group in the legend (and all layers that are part
of that group too).
"groupExpandInLegend" "true|false"
By default, groups initially start expanded to show the layers in that
group.  Setting this to false will start the group off 'collapsed'.
Cheers
Paul
On 11-Jul-08, at 12:37 PM, Nolte, Tim wrote:
> One issue that I have, and I found out why, is that my separate layers
> end up getting stuck together. (those that are in the same group).
> What
> I found out was that those layers that I have named like "Johnson
> City"
> aren't accessed correctly and able to be independently turned off.
> However, if I name the layer "JohnsonCity" with no spaces in the name
> then it works fine. The things about this is that what gets
> displayed in
> the Legend is that name and I don't want crapping looking layer
> titles.
> Also, something that I haven't figured out is how to completely hide
> certain layers from the legend that I use for dynamic purposes, that
> shouldn't be showing by default. Another problem I seem to have is
> that
> my legend icons don't all seem to be showing up correctly. Now this
> could be an issue with the version of UMN MapServer that I'm using. I
> did have to do some custom things to get these working in my other
> mapping framework.
> - Tim
> Timothy J Nolte - tnolte at ilpcs.com
> Network Planning Engineer
> iPCS Wireless, Inc.
> 4717 Broadmoor Ave, Suite G
> Kentwood, MI 49512
> Office: 616-656-5163
> PCS:    616-706-2438
> Fax:    616-554-6484
> Web: www.ipcswirelessinc.com
>> -----Original Message-----
>> From: fusion-users-bounces at lists.osgeo.org
>> [mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of
>> Jason Fournier
>> Sent: Friday, July 11, 2008 10:08 AM
>> To: fusion-users at lists.osgeo.org
>> Subject: RE: [fusion-users] MapServer + Fusion
>> Hi Tim,
>>> From my understanding you should not have to do too much
>> tweaking of your
>> MapFile to get it to work properly with Fusion.  Certain widgets will
>> require certain aspects of the MapFile to be present but you
>> should be able
>> to get a usable map without having to populate the MapFile
>> with extraneous
>> information.  What specifically are some of the issues you
>> are witnessing?
>> Jason
>> [mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of Nolte, Tim
>> Sent: Thursday, July 10, 2008 3:29 PM
>> Subject: [fusion-users] MapServer + Fusion
>> So was able to get something working by using files found under
>> fusion->templates->mapserver->standard for me use as samples.
>> I was able
>> to get the gmap demo data working and even my own current Production
>> MapServer .map file. There are a lot of strange issues that
>> make it seem
>> as though I'm going to need to make a new .map file that is tuned for
>> Fusion. I'm going to have to do some reading. Off hand, does
>> anyone have
>> any pointers? I'm thinking that I'm going to have to add a
>> bunch of meta
>> data for this to work correctly. Is Fusion using my MapServer
>> install/mapfile as a WMS or WFS source?
>> - Tim
>> iPCS Wireless, Inc.
>> Kentwood, MI 49512
>> PCS:    616-706-2438
>> Fax:    616-554-6484
>> fusion-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/fusion-users
    Paul Spencer
    Chief Technology Officer
    DM Solutions Group Inc
    http://www.dmsolutions.ca/
More information about the fusion-users mailing list
