[fusion-users] MapServer + Fusion
Nolte, Tim
Tim.Nolte at ipcswirelessinc.com
Fri Jul 11 15:44:51 EDT 2008
Paul,
Thank you a ton for the info.
- Tim
Timothy J Nolte - tnolte at ilpcs.com
Network Planning Engineer
iPCS Wireless, Inc.
4717 Broadmoor Ave, Suite G
Kentwood, MI 49512
Office: 616-656-5163
PCS: 616-706-2438
Fax: 616-554-6484
Web: www.ipcswirelessinc.com
> -----Original Message-----
> From: Paul Spencer [mailto:pspencer at dmsolutions.ca]
> Sent: Friday, July 11, 2008 2:04 PM
> To: Nolte, Tim
> Cc: Jason Fournier; fusion-users at lists.osgeo.org
> Subject: Re: [fusion-users] MapServer + Fusion
> Tim,
> there is a little bit of layer metadata that you can use to control
> how things appear in the legend.
> "displayInLegend" "true|false"
> By default, all layers are shown in the legend. If set to false, it
> will hide the layer in the legend
> "expandInLegend" "true|false"
> By default, all classified layers will show a sub-branch in
> the legend
> with all the classes. If set to false then the sub-branch is
> initially collapsed
> "legendLabel" "string value"
> By default, the layer's NAME value is used in the legend. If this
> metadata is set, then the value will be used in the legend instead.
> "selectable" "true|false"
> By default, layers are not 'selectable' using the select widget. If
> this is set to 'true' then the layer will be considered 'selectable'
> so the select widget will be enabled when this layer is selected in
> the legend.
> The legend will create folders for each group and put the
> appropriate
> layers in those groups. The groups respond to the following
> metadata
> in the first LAYER object in the group (first layer to use the group
> name)
> "groupLegendLabel" "string value"
> By default, the group name is used as the legend label. If this
> metadata is set then the value will be used instead of the group name.
> "groupDisplayInLegend" "true|false"
> By default, all groups are displayed in the legend. Setting this to
> false will hide the group in the legend (and all layers that
> are part
> of that group too).
> "groupExpandInLegend" "true|false"
> By default, groups initially start expanded to show the
> layers in that
> group. Setting this to false will start the group off 'collapsed'.
> Cheers
> Paul
> On 11-Jul-08, at 12:37 PM, Nolte, Tim wrote:
> > One issue that I have, and I found out why, is that my
> separate layers
> > end up getting stuck together. (those that are in the same group).
> > What
> > I found out was that those layers that I have named like "Johnson
> > City"
> > aren't accessed correctly and able to be independently turned off.
> > However, if I name the layer "JohnsonCity" with no spaces
> in the name
> > then it works fine. The things about this is that what gets
> > displayed in
> > the Legend is that name and I don't want crapping looking layer
> > titles.
> > Also, something that I haven't figured out is how to completely hide
> > certain layers from the legend that I use for dynamic purposes, that
> > shouldn't be showing by default. Another problem I seem to have is
> > that
> > my legend icons don't all seem to be showing up correctly. Now this
> > could be an issue with the version of UMN MapServer that
> I'm using. I
> > did have to do some custom things to get these working in my other
> > mapping framework.
> > - Tim
> > iPCS Wireless, Inc.
> > Kentwood, MI 49512
> > PCS: 616-706-2438
> > Fax: 616-554-6484
> >> From: fusion-users-bounces at lists.osgeo.org
> >> [mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of
> >> Jason Fournier
> >> Sent: Friday, July 11, 2008 10:08 AM
> >> To: fusion-users at lists.osgeo.org
> >> Subject: RE: [fusion-users] MapServer + Fusion
> >> Hi Tim,
> >>> From my understanding you should not have to do too much
> >> tweaking of your
> >> MapFile to get it to work properly with Fusion. Certain
> widgets will
> >> require certain aspects of the MapFile to be present but you
> >> should be able
> >> to get a usable map without having to populate the MapFile
> >> with extraneous
> >> information. What specifically are some of the issues you
> >> are witnessing?
> >> Jason
> Nolte, Tim
> >> Sent: Thursday, July 10, 2008 3:29 PM
> >> Subject: [fusion-users] MapServer + Fusion
> >> So was able to get something working by using files found under
> >> fusion->templates->mapserver->standard for me use as samples.
> >> I was able
> >> to get the gmap demo data working and even my own current
> Production
> >> MapServer .map file. There are a lot of strange issues that
> >> make it seem
> >> as though I'm going to need to make a new .map file that
> is tuned for
> >> Fusion. I'm going to have to do some reading. Off hand, does
> >> anyone have
> >> any pointers? I'm thinking that I'm going to have to add a
> >> bunch of meta
> >> data for this to work correctly. Is Fusion using my MapServer
> >> install/mapfile as a WMS or WFS source?
> >> - Tim
> >> iPCS Wireless, Inc.
> >> Kentwood, MI 49512
> >> PCS: 616-706-2438
> >> Fax: 616-554-6484
> >> _______________________________________________
> >> fusion-users mailing list
> >> http://lists.osgeo.org/mailman/listinfo/fusion-users
> Paul Spencer
> Chief Technology Officer
> DM Solutions Group Inc
> http://www.dmsolutions.ca/
More information about the fusion-users
