[fusion-users] Fusion + MapServer Function/Look Like MapGuide
Paul Spencer
pspencer at dmsolutions.ca
Wed Jul 16 08:43:11 EDT 2008
It should be possible :) You will need to spend some quality time
with firebug probably, but in essence you can get access to the
OpenLayers.Map instance and then do whatever you want. I would
probably approach it like this:
window.onload=function(){
Fusion.registerForEvent(Fusion.Event.FUSION_INITIALIZED,
fusionInitialized);
Fusion.registerForEvent(Fusion.Event.FUSION_ERROR, fusionError);
Fusion.initialize();
function fusionError(eventId, error) {
console.log('Fusion Error: '+error.toString();
function fusionInitialized(eventId) {
var map = Fusion.getWidgetById('Map'); // the id of the div
containing the map
var olMap = map.oMapOL;
var wms = new OpenLayers.Layer.WMS(/* parameters */);
olMap.addLayer(wms);
You will probably run into difficulty with the whole baseLayer thing
in OpenLayers. By default, most tile-based layers want to be base
layers and you need to add isBaseLayer: false to the layer options
(4th arg to WMS layer, might be different in other layer types).
You can also start Fusion without a map loaded and inject a baseLayer
using this method, but then a whole bunch of things won't really work
- for instance a lot of widgets only get enabled after a map has loaded.
Some feedback on *how* this should work would be appreciated. If you
have a particular use case and would like to be able to set things up
in a particular way, that would be very useful to the developers as we
plan out exposing more OpenLayers stuff.
Cheers
Paul
On 16-Jul-08, at 1:42 AM, David Percy wrote:
> Paul, thanks for the explanation on the tiling.
> I've actually been waiting to use and contribute to Fusion until the
> tiling was in place, as we currently use kamap for our tiling engine
> for the US geological survey, and it really helps. We are just
> working with Mootools and Openlayers, but I'd be happier if we were
> contributing to an active project, like Fusion, since that's the
> open source spirit.
> Is there a way to "wire" the unsupported Openlayers layer types into
> a Fusion app? It doesn't seem like it should be too difficult, but I
> was worried about making things hard to migrate once the Fusion
> framework supports it.
> I'd appreciate any thoughts you (or others on the PSC) have on this.
> Cheers,
> Percy
> Paul Spencer wrote:
>> Hi Tim,
>> you can get a Fusion application to look essentially like that
>> application using mapserver. The tiling capability on the client
>> side is implemented by OpenLayers, so there is nothing magically
>> mapguide about it. However, there is no support in the
>> ApplicationDefinition to let you define a tiled mapserver layer.
>> We are working on supporting all the OpenLayers layer types through
>> the ApplicationDefinition for the 1.1 release but this work has not
>> yet been done.
>> Even when the necessary hooks in Fusion are available, you will
>> still need something on the server side to generate the tiles. You
>> can use mapserver to do this directly, but it is pretty inefficient
>> since mapserver will draw the same tile over and over again. What
>> you need is something that will cache tiles for you and serve them
>> from the cache if available. For this, we will be recommending
>> either the kaMap's tile.php or TileCache.
>> Cheers
>> Paul
>> On 14-Jul-08, at 4:22 PM, Nolte, Tim wrote:
>>> OK, I know this is probably wishful thinking. AS I've looked at the
>>> MapGuide live app gallery. And specifically the following demo:
>>> http://data.mapguide.com/mapguide/phpviewersample/ajaxviewersample.php
>>> I would like to get Fusion (1.0.6) functioning and looking like that
>>> demo but using UMN MapServer. Is this even possible? Something I'm
>>> also
>>> wondering about is the Tiled AJAX sample. Is the tiling something
>>> specific and built in to MapGuide? I'm assuming the tiling is
>>> something
>>> on the server side and nothing to do with Fusion?
>>> - Tim
>>> Timothy J Nolte - tnolte at ilpcs.com
>>> Network Planning Engineer
>>> iPCS Wireless, Inc.
>>> 4717 Broadmoor Ave, Suite G
>>> Kentwood, MI 49512
>>> Office: 616-656-5163
>>> PCS: 616-706-2438
>>> Fax: 616-554-6484
>>> Web: www.ipcswirelessinc.com
>>> fusion-users mailing list
>>> fusion-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/fusion-users
>> Paul Spencer
>> Chief Technology Officer
>> DM Solutions Group Inc
>> http://www.dmsolutions.ca/
> David Percy
> Geospatial Data Manager
> Geology Department
> Portland State University
> http://gisgeek.pdx.edu
> 503-725-3373
Paul Spencer
More information about the fusion-users
