[fusion-users] Fusion Questions
Paul Spencer
pspencer at dmsolutions.ca
Wed Jul 16 08:26:49 EDT 2008
We need to think through how the navigator scale thing should work, I
think:
* it should be possible to set a min/max scale in the widget's
<Extension>
* it could possibly do a better job of picking up default min/max
scale from the map
* it should use a logarithmic scale for zooming, right now it is
linear and is really quite useless
I just took a look at the navigator code, it doesn't change the
position of the <div> that you put the navigator into. If you are
using templates/mapserver/standard to start from, you should be able
to add:
<style>
#Navigator {
right: 10px;
top: 10px;
</style>
in the <head> of that page to set the position of the navigator (by
default it should be at left:0, top:0 inside the <div> with id 'Map')
Regarding units, it is possible that the ViewOptions widget is
overriding your individual widget settings, try removing it from your
ApplicationDefinition. Note that right now we are using quite
inaccurate calculations for determining the decimal degrees of maps
not in a lonlat projection and also for calculating linear distances
from maps that are in decimal degrees. We plan to incorporate proj4js
especially for displaying the cursor position in lonlat when the map
is not in lonlat, and it should help in measuring distances too
because we can convert into projections defined in meters.
Cheers
Paul
On 16-Jul-08, at 8:03 AM, Nolte, Tim wrote:
> Ok, well I did manage to get the Navigator scale to be correct. It
> ended
> up being a matter of making sure I had no MAXSCALE parameters in my
> map
> file that were beyond what I set the overall MAXSCALE set to. It was a
> little bit of a pain to have to go through and modify so many layers
> but
> at least I got what I was after.
> I'll try to see what movement of the Navigator can be accomplished
> with
> just CSS. It's odd though because there is already automatically
> generated CSS on the Navigator that positions it where it's at.
> As far as the independent units for widgets, I did try using the
> <Units>
> tag inside <Extension> but that didn't give me any different results.
> The reason I asked this was that the MapGuide/Fusion example does have
> this for the CursorPosition & ViewSize widgets. I want the
> CursorPosition widget to be in decimal degrees (which I have already),
> and the ViewSize widget to be in miles.
> Thanks.
> Timothy J Nolte - tnolte at ilpcs.com
> Network Planning Engineer
> iPCS Wireless, Inc.
> 4717 Broadmoor Ave, Suite G
> Kentwood, MI 49512
> Office: 616-656-5163
> PCS: 616-706-2438
> Fax: 616-554-6484
> Web: www.ipcswirelessinc.com
>> -----Original Message-----
>> From: Paul Spencer [mailto:pspencer at dmsolutions.ca]
>> Sent: Tuesday, July 15, 2008 6:36 PM
>> To: Nolte, Tim
>> Cc: fusion-users at lists.osgeo.org
>> Subject: Re: [fusion-users] Fusion Questions
>> * The max scale of the navigator widget should be calculated
>> from the
>> extent defined in the map file. But the navigator is
>> currently poorly
>> implemented so it is quite possibly not working or difficult to work
>> with.
>> * you should be able to use css to reposition the navigator
>> * I don't think you can set independent units for widgets but if you
>> can, then you would add <Units>meters</Units> (with the appropriate
>> unit) to the widget's <Extension> in the ApplicationDefinition.xml
>> Cheers
>> Paul
>> On 15-Jul-08, at 4:39 PM, Nolte, Tim wrote:
>>> Have a few questions:
>>> 1. How do you changing the max scale/zoom of the Navigator widget?
>>> 2. How do you set the navigator to be on the right side of
>> the map by
>>> default?
>>> 3. How do you set different independent units for the
>> CursorPosition &
>>> ViewSize widgets?
>>> Thanks!
>>> - Tim
>>> iPCS Wireless, Inc.
>>> Kentwood, MI 49512
>>> PCS: 616-706-2438
>>> Fax: 616-554-6484
>>> fusion-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/fusion-users
>> Paul Spencer
>> Chief Technology Officer
>> DM Solutions Group Inc
>> http://www.dmsolutions.ca/
Paul Spencer
More information about the fusion-users
