[fusion-users] Fusion classes and operability.
Mike Adair
madair at dmsolutions.ca
Thu Jul 17 10:42:40 EDT 2008
Tomas,
There is some documentation on using/extending Fusion events on the
wiki: http://trac.osgeo.org/fusion/wiki/Cookbook/Fusion/Events
For your other question, I think you are asking about 2 different widget
instances that inherit from the same base class, sharing some form of
storage defined in the base class? If so, you may be able to use
JavaScript closures? http://www.jibbering.com/faq/faq_notes/closures.html
Mike
Tómas Guðmundsson wrote:
> Hi all.
> I might have asked this before but I‘m keen on knowing how to perform
> some things. How do I pass on functions between two fusion classes? I
> know about the inheritance, like a widget can inherit from a
> ButtonBase tool. But if I would like to maintain some kind of data
> structure of data in a class, let‘s say called Fusion.Tool.Container.
> How, if two seperate widget‘s would use the inherit method, could the
> call methods that would effect the same instance of the Container?
> Let‘s say one would call
> this.containerWrite('mystring');
> And the other
> this.containerRead();
> Given that containerWrite would write to the place where conatinerRead
> reads, would I get back 'mystring'?
> Also, does anyone know of a good place where I can see how event's are
> written (i.e. in the code) ? That is, how to create a new Event within
> Fusion.Event ?
> Kind regards,
> Tómas.
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
More information about the fusion-users
