[fusion-users] How to map.getSelection(). Ps.: Are you receiving
my text message?
Alan Boudreault
aboudreault at mapgears.com
Fri May 2 21:47:12 EDT 2008
Hi Vitor,
First, yes.. we have received your message :)
About your question. It's always a good thing to tell us what is the
cartographic web software (MapGuide and MapServer) that you use. Some
parts of Fusion will depends of this software. Let's me know what part
of Fuson that you use and i will try to help you.
regards,
Alan
Sapucaia wrote:
> Hi list!
> I've sent this message a week ago, but I'm not sure if you recieved
> the hole message (message body).
> So, I am sending one more time. Please, at least reply me a
> confirmation =]
> First of all, I am Vitor Fortunato, from Brazil, and I am developing
> an application based on Fusion as my last work for graduation
> (monography). So I decided to bring more features to Fusion.
> I need some directions to use the method map.getSelection(callback,
> layers, startcount).
> After select some features in the map, am I able to call this method
> and return all selected features (ids) and layers names?
> My point is to do an Attribute Table, that persists in PostGIS.
> I've started a new widget and I want to get the selected features ids
> and layers names of each feature after select some features and
> execute the button that call the Attribute Table.
> My widget is attached in this mail. Note that I am just starting to
> use Fusion and some code may be incorrect.
> This is the first version that look just for the active layer to make
> the grid.
> The file:
> http://lists.osgeo.org/pipermail/fusion-users/attachments/20080427/1214aa04/AttTable-0001.js
> Thanks in advance!
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
Alan Boudreault
Mapgears
http://www.mapgears.com/
More information about the fusion-users
