[fusion-users] Installing and Configuring Fusion 1.1 with MapGuide
2.0.2 WinXP/PHP/Apache
Mike Toews
mwtoews at sfu.ca
Tue Nov 4 13:08:46 EST 2008
Hi all,
I'd like to try the latest 1.1 release of Fusion with MapGuideOS 2.0.2
on a WinXP system with PHP/Apache, however the instructions at
http://trac.osgeo.org/fusion/wiki/FusionInstallationConfiguration fall
short of enabling this.
* For Windows step 3, there is no file named
"fusion/config_dist.json", but there is a file named
"config.json". This step does not make sense, and has ambiguous
"modify the settings for your system configuration" language
without explaining exactly what needs to be modified. Is there a
canned version of the file that can be put in here for users like
myself that have a standard, non-customized install?
* For Windows step 4, the path www/fusion/samples/mapguide/ does not
exist on the filesystem, so I don't see how
http://localhost:8008/mapguide/fusion/samples/mapguide/ can work.
Was step 2 really unzip all of fusion into www/ ? Is this the
correct URL?
Thanks in advance.
-Mike
More information about the fusion-users
