[fusion-users] Simple question about MapGuide tiling
Andrew Parker
andrew at source3.com
Thu Nov 6 09:34:26 EST 2008
Stuart:
I do not have an answer for you. But I am starting work on a similar
problem today and would like to have a solution by next Wednesday.
Below is a brief description of what I am trying to do. FYI: I am not a
developer so I have no idea how to go about doing this; but I have a
programmer to turn to for help.
I am running Fusion for MapServer. I have not installed Mapguide OS. I
want to enable tiling for this site: http://pitrule.source3.com. And
change my "Base Map" group in the Legend from checkboxes (overlay) to
radio buttons (basemap).
All the threads I have seen talks about using MapGuide, but I have not
found any howto's or suggestions to implement tiling for Fusion for
MapServer. I am clearly not understanding something.
Lastly, when I figure out how to do this, I will be creating a howto.
In addition, I will create a new topic for my progress as I do not want
to impose on your thread.
Good luck and if I see a solution for your issue I will let you know.
~ Andrew
gingerbbm wrote:
> Right, well I found this thread:
> http://n2.nabble.com/Fusion---Base-layers-questions...-td1303997.html
> So again I need to find a workaround...
More information about the fusion-users
