[fusion-users] Simple question about MapGuide tiling
Paul Spencer
pspencer at dmsolutions.ca
Thu Nov 6 09:48:15 EST 2008
Hi Andrew,
you might be able to get it to tile your requests by adding
<singleTile>false</singleTile> to the <Map> or <Map><Extension> tag in
your application definition, but that won't cache the tiles so it will
be hard on the server. Then again, I haven't really tried doing this
so the MapServer stuff in Fusion may ignore singleTile.
We are adding support for all OpenLayers layer types soon and then you
can specify a WMS layer or TMS layer and point it to a TileCache
instance that uses MapServer to generate the map tiles. It should be
in SVN in a week or two and be officially supported in the 2.0 release
that should be out before the end of the year.
Cheers
Paul
On 6-Nov-08, at 9:34 AM, Andrew Parker wrote:
> Stuart:
> I do not have an answer for you. But I am starting work on a
> similar problem today and would like to have a solution by next
> Wednesday. Below is a brief description of what I am trying to do.
> FYI: I am not a developer so I have no idea how to go about doing
> this; but I have a programmer to turn to for help.
> I am running Fusion for MapServer. I have not installed Mapguide
> OS. I want to enable tiling for this site: http://pitrule.source3.com
> . And change my "Base Map" group in the Legend from checkboxes
> (overlay) to radio buttons (basemap).
> All the threads I have seen talks about using MapGuide, but I have
> not found any howto's or suggestions to implement tiling for Fusion
> for MapServer. I am clearly not understanding something.
> Lastly, when I figure out how to do this, I will be creating a
> howto. In addition, I will create a new topic for my progress as I
> do not want to impose on your thread.
> Good luck and if I see a solution for your issue I will let you know.
> ~ Andrew
> gingerbbm wrote:
>> Right, well I found this thread:
>> http://n2.nabble.com/Fusion---Base-layers-questions...-td1303997.html
>> So again I need to find a workaround...
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
Paul Spencer
Chief Technology Officer
DM Solutions Group Inc
http://research.dmsolutions.ca/
More information about the fusion-users
