[fusion-users] Simple question about MapGuide tiling
gingerbbm
stuart.jones at jacobs.com
Thu Nov 6 12:53:44 EST 2008
I might as well give up on that then.
It's a real shame. All this great software exists (MapGuide; Fusion;
OpenLayers), is freely available, and is lovingly and brilliantly supported
by the community but everything I've tried to do with it has ultimately been
thwarted.
I need a tiled base map with up to twenty switchable overlay layers, with
tooltips working on points, lines and polygons. On top of that the ability
to digitize a line, point or poly temporarily.
I can have all of that with OpenLayers - except for the tooltips because
MapGuide WMS doesn't work fully.
I can have all of that with Fusion - except for the tiled base map because I
can't combine different layer types.
I can have all of that with the Ajax viewer - except that the interface is
then restricted to frame hell.
</rant>
I do appreciate your continued help.
Thanks
Stuart
View this message in context: http://n2.nabble.com/Simple-question-about-MapGuide-tiling-tp1460396p1466052.html
Sent from the Fusion Users mailing list archive at Nabble.com.
More information about the fusion-users
