[fusion-users] Printing widget does not create map.
Andrew Parker andrew at source3.com
Mon Nov 10 19:05:10 EST 2008
Hello  folks:
I am having Gregor at HostGIS help me out getting the print widget to
work (http://pitrule.source3.com).  Gregor has isolated the error as
discussed below. Does anyone have any helpful hints.
Thanks,
Andrew
Gregor Mosheh wrote:
> The printing is failing with this error. This is straightforward: the
> printing code is trying to call a function which doesn't exist.
>    PHP Fatal error:  Call to undefined function MgInitializeWebTier()
>    in /var/www/htdocs/fusion/MapGuide/php/Common.php on line 67
> Where this function would have been defined, I could not guess. It
> doesn't appear in any files, and I see no other errors about include
> files missing. You'll have to refer this to the Fusion mailing list,
> since it's a bug in their software which I cannot fix.
More information about the fusion-users mailing list
