[fusion-users] Printing widget does not create map.
Paul Spencer pspencer at dmsolutions.ca
Mon Nov 10 20:56:53 EST 2008
The print widget appears to only support MapGuide.  There should be a
MapGuide and MapServer directory under widgets/Print and the existing
code should have been moved into a MapGuide support directory.  No-one
has written print support for MapServer in the Fusion framework yet.
There are a couple of other widgets that I suspect fall into this
category (poorly structured and not implemented for MapServer).
I have filed http://trac.osgeo.org/fusion/ticket/166 to track this task.
Sorry for the inconvenience.
Cheers
Paul
On 10-Nov-08, at 7:05 PM, Andrew Parker wrote:
> Hello  folks:
> I am having Gregor at HostGIS help me out getting the print widget
> to work (http://pitrule.source3.com).  Gregor has isolated the error
> as discussed below. Does anyone have any helpful hints.
> Thanks,
> Andrew
> Gregor Mosheh wrote:
>> The printing is failing with this error. This is straightforward:
>> the printing code is trying to call a function which doesn't exist.
>>   PHP Fatal error:  Call to undefined function MgInitializeWebTier()
>>   in /var/www/htdocs/fusion/MapGuide/php/Common.php on line 67
>> Where this function would have been defined, I could not guess. It
>> doesn't appear in any files, and I see no other errors about
>> include files missing. You'll have to refer this to the Fusion
>> mailing list, since it's a bug in their software which I cannot fix.
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
    Paul Spencer
    Chief Technology Officer
    DM Solutions Group Inc
    http://research.dmsolutions.ca/
More information about the fusion-users mailing list
