[fusion-users] Using MapGuide Overlays with Commercial Map Service Layers
Pedro Venâncio pedrongvenancio at yahoo.com
Sun Aug 30 10:36:38 EDT 2009
Hello Paul
 First of all, thanks for your answer.
 I started to install PHP with .NET, but did not work and other templates (slate, aqua, ...) also failed to load.
Then I did a clean install of Mapguide with PHP on a virtual machine,
replaced the fusion folder with all files contained on this
page http://svn.osgeo.org/fusion/trunk/, overwrite the folder templates and finally follow the steps
listed here http://trac.osgeo.org/fusion/wiki/MapGuideCommercialOverlays.
 However, the result was, again, a blank page (I´m using Firefox 3.5.2).
 Is there anything else I can try?
 Thank you very much!
 Regards,
 Pedro
--- On Sat, 8/29/09, Paul Spencer <pspencer at dmsolutions.ca> wrote:
Fusion doesn't have any support for .NET at this time, it would require all the PHP scripts to be ported to .NET.  I believe that it is possible to mix the two, using PHP for the stock fusion stuff and using .NET for tasks to be run in the task pane.
If you want to update fusion, you should:
1) rename fusion to fusion.old (or something like that)
2) check out fusion/trunk from svn and put it in the same place as fusion.old
3) copy fusion.old/templates and paste over fusion/templates (replace the one from fusion svn as it does not come with the mapguide templates)
Cheers
Paul
On 2009-08-28, at 9:03 AM, Pedro Venâncio wrote:
> Hello everyone!
> I was trying to load google maps on fusion, following the instructions in "Using MapGuide Commercial Overlays with Map Service Layers", but ignoring the step "Fusion svn checkout in place of the bundled fusion installation". At the end, when I start the application, just get a blank page.
> When I see the instructions to replace the bundled fusion installation, I noticed that this tutorial only works with installations with PHP, and I'm using MGOS2.1b with .NET.
> Thus, to load the Commercial Service Map Layers, it is mandatory to do with PHP installation, then install the Fusion svn checkout and then follow the steps in the tutorial? To install the svn, it is sufficient to erase the contents of the folder fusion in /www/fusion/ and copy the files that are in http://svn.osgeo.org/fusion/trunk/?
> Regards,
> Pedro Venancio
> PS: At this moment I'm running MGOS2.1 beta1 with IIS5.1 and. NET on Windows XP Pro w/SP2.
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
   Paul Spencer
   Chief Technology Officer
   DM Solutions Group Inc
   http://research.dmsolutions.ca/
URL: http://lists.osgeo.org/pipermail/fusion-users/attachments/20090830/eff45839/attachment.html
More information about the fusion-users mailing list
