[fusion-users] Using MapGuide Overlays with Commercial Map Service Layers
Paul Spencer pspencer at dmsolutions.ca
Mon Aug 31 08:20:58 EDT 2009
Do you get any error messages?  The best browser to try this in is
firefox with the firebug extension enabled, the console tab often
gives you a very good idea of what is going wrong.
Cheers
Paul
(oh and yes, the next beta will have everything set up correctly)
On 2009-08-31, at 7:16 AM, Pedro Venâncio wrote:
> Paul
> Once again, thanks for your reply.
> The script tag in standard/index.html is already fusion.js (<script
> type="text/javascript" src="../../../lib/fusion.js"></ script>) and
> lib folder in svn ( http://svn.osgeo.org/fusion/trunk/lib/ ) only
> contains the fusion.js.
> Right now I do not have enough knowledge to make a build, so I will
> wait for the next beta release, which I suppose will include all the
> changes, I am right?
> Thank you very much!
> Regards,
> Pedro
> --- On Mon, 8/31/09, Paul Spencer <pspencer at dmsolutions.ca> wrote:
> I suspect the templates are expecting a 'single file build' of
> fusion, which I guess is not in SVN.  You can edit the index.html
> file and change the script tag that includes fusionSF.js to be just
> fusion.js OR you can get the Apache ANT build system and run the
> build file (build.xml) to create fusionSF.js and place it in the
> fusion/lib directory.
> Cheers
> Paul
> On 2009-08-30, at 10:36 AM, Pedro Venâncio wrote:
> > Hello Paul
> > First of all, thanks for your answer.
> > I started to install PHP with .NET, but did not work and other
> templates (slate, aqua, ...) also failed to load.
> > Then I did a clean install of Mapguide with PHP on a virtual
> machine, replaced the fusion folder with all files contained on this
> page http://svn.osgeo.org/fusion/trunk/, overwrite the folder
> templates and finally follow the steps listed here http://trac.osgeo.org/fusion/wiki/MapGuideCommercialOverlays
> > However, the result was, again, a blank page (I´m using Firefox
> 3.5.2).
> > Is there anything else I can try?
> > Regards,
> > Pedro
> > --- On Sat, 8/29/09, Paul Spencer <pspencer at dmsolutions.ca> wrote:
> > Fusion doesn't have any support for .NET at this time, it would
> require all the PHP scripts to be ported to .NET.  I believe that it
> is possible to mix the two, using PHP for the stock fusion stuff and
> using .NET for tasks to be run in the task pane.
> > If you want to update fusion, you should:
> > 1) rename fusion to fusion.old (or something like that)
> > 2) check out fusion/trunk from svn and put it in the same place as
> fusion.old
> > 3) copy fusion.old/templates and paste over fusion/templates
> (replace the one from fusion svn as it does not come with the
> mapguide templates)
> > Cheers
> > Paul
> > On 2009-08-28, at 9:03 AM, Pedro Venâncio wrote:
> > > Hello everyone!
> > > I was trying to load google maps on fusion, following the
> instructions in "Using MapGuide Commercial Overlays with Map Service
> Layers", but ignoring the step "Fusion svn checkout in place of the
> bundled fusion installation". At the end, when I start the
> application, just get a blank page.
> > > When I see the instructions to replace the bundled fusion
> installation, I noticed that this tutorial only works with
> installations with PHP, and I'm using MGOS2.1b with .NET.
> > > Thus, to load the Commercial Service Map Layers, it is mandatory
> to do with PHP installation, then install the Fusion svn checkout
> and then follow the steps in the tutorial? To install the svn, it is
> sufficient to erase the contents of the folder fusion in /www/
> fusion/ and copy the files that are in http://svn.osgeo.org/fusion/trunk/?
> > > Regards,
> > > Pedro Venancio
> > > PS: At this moment I'm running MGOS2.1 beta1 with IIS5.1 and.
> NET on Windows XP Pro w/SP2.
> > > _______________________________________________
> > > fusion-users mailing list
> > > fusion-users at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/fusion-users
> >    Paul Spencer
> >    Chief Technology Officer
> >    DM Solutions Group Inc
> >    http://research.dmsolutions.ca/
>    Paul Spencer
    Paul Spencer
More information about the fusion-users mailing list
