[fusion-users] Using MapGuide Overlays with Commercial Map
Service Layers
Pedro Venâncio
pedrongvenancio at yahoo.com
Mon Aug 31 09:15:05 EDT 2009
Hello Paul,
No, I don't get any error message, just a blank page (with firefox 3.5.2).
So I guess I'll wait for the next beta release!
Thank you very much for your help Paul!
Regards,
Pedro
--- On Mon, 8/31/09, Paul Spencer <pspencer at dmsolutions.ca> wrote:
Do you get any error messages? The best browser to try this in is firefox with the firebug extension enabled, the console tab often gives you a very good idea of what is going wrong.
Cheers
Paul
(oh and yes, the next beta will have everything set up correctly)
On 2009-08-31, at 7:16 AM, Pedro Venâncio wrote:
> Paul
> Once again, thanks for your reply.
> The script tag in standard/index.html is already fusion.js (<script type="text/javascript" src="../../../lib/fusion.js"></ script>) and lib folder in svn ( http://svn.osgeo.org/fusion/trunk/lib/ ) only contains the fusion.js.
> Right now I do not have enough knowledge to make a build, so I will wait for the next beta release, which I suppose will include all the changes, I am right?
> Thank you very much!
> Regards,
> Pedro
> I suspect the templates are expecting a 'single file build' of fusion, which I guess is not in SVN. You can edit the index.html file and change the script tag that includes fusionSF.js to be just fusion.js OR you can get the Apache ANT build system and run the build file (build.xml) to create fusionSF.js and place it in the fusion/lib directory.
> Cheers
> Paul
> On 2009-08-30, at 10:36 AM, Pedro Venâncio wrote:
> > Hello Paul
> > First of all, thanks for your answer.
> > I started to install PHP with .NET, but did not work and other templates (slate, aqua, ...) also failed to load.
> > Then I did a clean install of Mapguide with PHP on a virtual machine, replaced the fusion folder with all files contained on this page http://svn.osgeo.org/fusion/trunk/, overwrite the folder templates and finally follow the steps listed here http://trac.osgeo.org/fusion/wiki/MapGuideCommercialOverlays.
> > However, the result was, again, a blank page (I´m using Firefox 3.5.2).
> > Is there anything else I can try?
> > Regards,
> > Pedro
> > --- On Sat, 8/29/09, Paul Spencer <pspencer at dmsolutions.ca> wrote:
> > Fusion doesn't have any support for .NET at this time, it would require all the PHP scripts to be ported to .NET. I believe that it is possible to mix the two, using PHP for the stock fusion stuff and using .NET for tasks to be run in the task pane.
> > If you want to update fusion, you should:
> > 1) rename fusion to fusion.old (or something like that)
> > 2) check out fusion/trunk from svn and put it in the same place as fusion.old
> > 3) copy fusion.old/templates and paste over fusion/templates (replace the one from fusion svn as it does not come with the mapguide templates)
> > Cheers
> > Paul
> > On 2009-08-28, at 9:03 AM, Pedro Venâncio wrote:
> > > Hello everyone!
> > > I was trying to load google maps on fusion, following the instructions in "Using MapGuide Commercial Overlays with Map Service Layers", but ignoring the step "Fusion svn checkout in place of the bundled fusion installation". At the end, when I start the application, just get a blank page.
> > > When I see the instructions to replace the bundled fusion installation, I noticed that this tutorial only works with installations with PHP, and I'm using MGOS2.1b with .NET.
> > > Thus, to load the Commercial Service Map Layers, it is mandatory to do with PHP installation, then install the Fusion svn checkout and then follow the steps in the tutorial? To install the svn, it is sufficient to erase the contents of the folder fusion in /www/fusion/ and copy the files that are in http://svn.osgeo.org/fusion/trunk/?
> > > Regards,
> > > Pedro Venancio
> > > PS: At this moment I'm running MGOS2.1 beta1 with IIS5.1 and. NET on Windows XP Pro w/SP2.
> > > _______________________________________________
> > > fusion-users mailing list
> > > fusion-users at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/fusion-users
> > Paul Spencer
> > Chief Technology Officer
> > DM Solutions Group Inc
> > http://research.dmsolutions.ca/
> Paul Spencer
Paul Spencer
URL: http://lists.osgeo.org/pipermail/fusion-users/attachments/20090831/f4fc26dc/attachment.html
More information about the fusion-users
