[fusion-users] MapGuide Ent 2010: Fusion and digitize error
Matteo matteo.conte1979 at libero.it
Fri Jul 3 03:05:01 EDT 2009
Hi Paul,
   I give the same error in IE and Firefox. The file CanvasTool.js don't
have a getMap function so to resolve the problem I must add this function to
the file
getMap: function() {
	    var map=this.oMap;
		if (typeof(map) == "undefined"){
		  map=this.map;
		return map;
Now works fine
Regards Matteo
Paul Spencer-2 wrote:
> It seems like your template is using the single file, compressed build
> of Fusion ... which is singularly unhelpful for debugging problems
> since the code is stripped down.  You need to change the template's
> index.html file to using fusion.js instead of fusionSF.js (or whatever
> it is) and then we might get some more helpful errors.
> What web browser are you using?  IE?  Do you get the same error in
> other browsers (i.e. Firefox)
> Paul
> On 2-Jul-09, at 8:27 AM, Matteo wrote:
>> Hi,
>>  I try to develop an application with Fusion for draw some object.
>> When I
>> call the digitize function of MapGuideViewerApi.js (ex
>> DigitizePolygon) I
>> get an error on activateCanvas function at this line
>> var C=this.getMap()
>> Can you help me?
>> Regards Matteo
>> View this message in context:
>> http://n2.nabble.com/MapGuide-Ent-2010%3A-Fusion-and-digitize-error-tp3194766p3194766.html
>> Sent from the Fusion Users mailing list archive at Nabble.com.
>> fusion-users mailing list
>> fusion-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/fusion-users
>     Paul Spencer
>     Chief Technology Officer
>     DM Solutions Group Inc
>     http://research.dmsolutions.ca/
View this message in context: http://n2.nabble.com/MapGuide-Ent-2010%3A-Fusion-and-digitize-error-tp3194766p3199859.html
More information about the fusion-users mailing list
