AW: [fusion-users] Using fusion with Tabs (Jx.Button.Tab, etc.)
Bernhard Schneider bernhard.schneider at ilu.ch
Fri Jun 12 09:47:17 EDT 2009
Thank you for your very fast reply!
I tested your suggestion, but it didn't work. I think the reason is the effect of the visibility:hidden on child nodes. The setting display:none prevents all children of the div element from being shown, whatever their display and visibility settings are. I suspect that this is not the case for visibility:hidden, some of the div's children are still shown.
I wonder whether I should set display:block of the tab with the Fusion map before Fusion is initialized, and put display back to none after Fusion initalization. This however would cause the map to appear briefly. To prevent this, I could move the map's parent div out of the way by setting top:10000 and left:10000, but all of this is kind of ugly.
Is it OpenLayers that retrieves the map size from the clientWidth and clientHeight attributes? Or is it Fusion? Are there any reasons for not using the regular width and height attributes of the map's parent div?
I'll keep working on it...
Bernhard
-----Ursprüngliche Nachricht-----
Von: Paul Spencer [mailto:pspencer at dmsolutions.ca]
Gesendet: Freitag, 12. Juni 2009 14:31
An: Bernhard Schneider
Cc: fusion-users at lists.osgeo.org
Betreff: Re: [fusion-users] Using fusion with Tabs (Jx.Button.Tab, etc.)
Tough one!  Ideally, the tabs would be set to display: block;
visibility: hidden; .  You can try this (untested)
<style>
.tabContent {
   display: block;
   visibility: hidden;
.tabContentActive {
   visibility: visible;
</style>
and include that AFTER the jxlib theme file <link> in your page.  If
that doesn't work, check in firebug to see which styles are getting
used for tab content areas, if it is still .tabContent from the theme
file then try adding !important before the ; on each line above (i.e.
display: block !important;)
Cheers
Paul
On 12-Jun-09, at 8:18 AM, Bernhard Schneider wrote:
> Hello Fusion users and expert,
> We are trying to use Fusion (2 beta) in combination with Tabs
> (Jx.Button.Tab, Jx.TabSet). We encounter the following problem when
> loading Fusion in a tab that is currently not active: If a tab is
> inactive, some of the tab's div-elements are not visible
> (display=none). Because of this, all requests to div-
> element.clientWidth and ..clientHeight return 0 (instead of the
> actual element's size). This in turn is bad for the map widget
> because it needs these div attributes to determine its size. When
> the user clicks the tab with the Fusion map, the damage is already
> done, a generic max extent is used instead of the predefined one,
> and the overview map does not show at all.
> As it turns out, we only manage to successfully load Fusion in
> active tabs.
> Does anyone have experience in loading Fusion in tabs? Any
> suggestions on how to load Fusion in inactive tabs?
> Thank you in advance
> Bernhard
> fusion-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fusion-users
    Paul Spencer
    Chief Technology Officer
    DM Solutions Group Inc
    http://research.dmsolutions.ca/
More information about the fusion-users mailing list
