AW: [fusion-users] Using fusion with Tabs (Jx.Button.Tab, etc.)
Paul Spencer
pspencer at dmsolutions.ca
Fri Jun 12 11:07:52 EDT 2009
Um, I just tried this in the fusion/templates/mapserver/ template and
it worked fine. javascript errors without the css, no errors with the
css:
<style>
.tabContent {
display: block !important;
visibility: hidden !important;
.tabContentActive {
visibility: visible !important;
</style>
I added the above css at the end of the head section.
I modified new Jx.Splitter to change 'Map' for 'TabbedArea' and added
a new TabBox to contain an empty tab (active) and a map tab:
new Jx.Splitter(mainPanel.content, {
elements: ['PanelPane', 'TabbedArea'],
containerOptions: [{width: 200}, {}]
new Jx.Layout('Map');
var tb = new Jx.TabBox().addTo('TabbedArea');
tb.add(
new Jx.Button.Tab({label: 'another tab'}),
new Jx.Button.Tab({label: 'Map Tab', content: 'Map'})
and I modified the HTML to put a div called TabbedArea around the
<div id="TabbedArea">
<div id="Map"><div id="Navigator"></div>
</div>
Cheers
Paul
On 12-Jun-09, at 9:47 AM, Bernhard Schneider wrote:
> Thank you for your very fast reply!
> I tested your suggestion, but it didn't work. I think the reason is
> the effect of the visibility:hidden on child nodes. The setting
> display:none prevents all children of the div element from being
> shown, whatever their display and visibility settings are. I suspect
> that this is not the case for visibility:hidden, some of the div's
> children are still shown.
> I wonder whether I should set display:block of the tab with the
> Fusion map before Fusion is initialized, and put display back to
> none after Fusion initalization. This however would cause the map to
> appear briefly. To prevent this, I could move the map's parent div
> out of the way by setting top:10000 and left:10000, but all of this
> is kind of ugly.
> Is it OpenLayers that retrieves the map size from the clientWidth
> and clientHeight attributes? Or is it Fusion? Are there any reasons
> for not using the regular width and height attributes of the map's
> parent div?
> I'll keep working on it...
> Bernhard
> -----Ursprüngliche Nachricht-----
> Von: Paul Spencer [mailto:pspencer at dmsolutions.ca]
> Gesendet: Freitag, 12. Juni 2009 14:31
> An: Bernhard Schneider
> Cc: fusion-users at lists.osgeo.org
> Betreff: Re: [fusion-users] Using fusion with Tabs (Jx.Button.Tab,
> etc.)
> Tough one! Ideally, the tabs would be set to display: block;
> visibility: hidden; . You can try this (untested)
> <style>
> .tabContent {
> display: block;
> visibility: hidden;
> .tabContentActive {
> visibility: visible;
> </style>
> and include that AFTER the jxlib theme file <link> in your page. If
> that doesn't work, check in firebug to see which styles are getting
> used for tab content areas, if it is still .tabContent from the theme
> file then try adding !important before the ; on each line above (i.e.
> display: block !important;)
> Cheers
> Paul
> On 12-Jun-09, at 8:18 AM, Bernhard Schneider wrote:
>> Hello Fusion users and expert,
>> We are trying to use Fusion (2 beta) in combination with Tabs
>> (Jx.Button.Tab, Jx.TabSet). We encounter the following problem when
>> loading Fusion in a tab that is currently not active: If a tab is
>> inactive, some of the tab's div-elements are not visible
>> (display=none). Because of this, all requests to div-
>> element.clientWidth and ..clientHeight return 0 (instead of the
>> actual element's size). This in turn is bad for the map widget
>> because it needs these div attributes to determine its size. When
>> the user clicks the tab with the Fusion map, the damage is already
>> done, a generic max extent is used instead of the predefined one,
>> and the overview map does not show at all.
>> As it turns out, we only manage to successfully load Fusion in
>> active tabs.
>> Does anyone have experience in loading Fusion in tabs? Any
>> suggestions on how to load Fusion in inactive tabs?
>> Thank you in advance
>> Bernhard
>> fusion-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/fusion-users
> Paul Spencer
> Chief Technology Officer
> DM Solutions Group Inc
> http://research.dmsolutions.ca/
Paul Spencer
More information about the fusion-users
