[fusion-users] Re: Scale problem when using fusion.js instead of
fusionSF-compressed.js
jcabrera
jecabreraa at hotmail.com
Wed Apr 28 11:35:27 EDT 2010
Did you ever figured this one out? I am having the same problem.
Jorge
Ari Þórðarson wrote:
> Hi all
> I just installed MapGuide Open Source 2.1 final release
> and have the version of fusion that comes with that
> release.
> I changed the line in the slate template from this:
> <script type="text/javascript"
> src="../../../lib/fusionSF-compressed.js"></script>
> to this
> <script type="text/javascript" src="../../../lib/fusion.js"></script>
> When I load the page the scale in the map is wrong when
> using "fusion.js" instead of "fusionSF-compressed.js".
> This does not happen with the Sheboygan map, but it does
> happen when I am using a map that I have.
> Doeas anyone recognize this problem?
> Is there any difference between using fusion.js and
> fusionSF-compressed.js or might it be that there is
> something wrong with the map I am using?
> I would be thankfull for any help.
> Best regards, Ari
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Scale-problem-when-using-fusion-js-instead-of-fusionSF-compressed-js-tp4414131p4975161.html
Sent from the Fusion Users mailing list archive at Nabble.com.
More information about the fusion-users
