[fusion-users] Passing username, password, db, and host to
Paul Deschamps
pdeschamps at dmsolutions.ca
Fri Jan 15 10:02:46 EST 2010
Hi Bernhard,
To my knowledge none of the fusion widgets connect to any database. Are you
asking how you would create a FUSION widget that would include some
connection to this database?
All of the widgets would access your postgres layers through php_mapscript
which in turn would call on mapserver to make the connection for it.
Cheers
Paul.
On Wed, Jun 11, 2008 at 11:07 AM, Bernhard Schneider <
bernhard.schneider at ilu.ch> wrote:
> Hi everyone,
> This may be a stupid question, but if someone still could point me in the
> right direction...?
> My Fusion application reads the map information from a map file. (I am
> using MapServer 5.something.) The map file references a number of layers in
> a PostgreSQL/PostGIS database. In the map file, information on user,
> password, database, and host are given as follows:
> CONNECTION "user=%PHP_AUTH_USER% password=%PHP_AUTH_PW% dbname=%DB%
> host=localhost"
> Is there a way to pass the information to connect to the database to
> Fusion? Or should I use another way of referencing this information in the
> map file? Or is there a documentation on this issue that I missed?
> Thanks in advance.
> Bernhard
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
Paul Deschamps
Applications Specialist
DM Solutions Group Inc.
Office: (613) 565-5056 x28
http://www.dmsolutions.ca
http://research.dmsolutions.ca
URL: http://lists.osgeo.org/pipermail/fusion-users/attachments/20100115/58ad415c/attachment.html
More information about the fusion-users
