[fusion-users] v2.0.0 release candidate available
Berdel, Brian brian.berdel at mcmtrans.com
Thu Mar 25 15:27:18 EDT 2010
I still see the Legend issues I posted yesterday (see below), which I think are a major issue. I didn't receive a response so I am not sure if it is just me or not...But I am using the standard templates and sample data.  IE7 IE8 and FireFox 3.6.
I can open a ticket, but I wanted to check if anyone else has experienced this.  I searched and did not find anything.
I am getting a couple error in the SVN version using Sheboygan data / standard templates or my own templates.  When opening the Map with Two Maps (Using one as a base map)  I get 'LegendLabel' is null or not an object in legend.js (Line 9 in createTreeItem) and the variable style is coming in as null.
1 createTreeItem: function(layer, style, scale, bCheckBox) {
2        var opt = {};
3        opt.statusIsDefault = layer.statusDefault;
4
5        if (bCheckBox ) {
6            opt.label = layer.legendLabel == '' ? ' ' : layer.legendLabel;
7            opt.draw = this.renderItemCheckBox;
8        } else {
9            opt.label = style.legendLabel == '' ? ' ' : style.legendLabel;
            opt.draw = this.renderItem;
The Base map is also displayed on open even though I have the layer set to off and the check box for the layer is also not checked.   So I have to check it and then uncheck to turn it off.
Also the following occurs with one or two maps.
Clicking on the map name check box also throws an error, and it turns off but not back on...
Line: 1038 of Mapguide.js
Error: 'this.oLayerOL2' is null or not an object
Thanks,
Brian
-----Original Message-----
From: fusion-users-bounces at lists.osgeo.org [mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of Mike Adair
Sent: Thursday, March 25, 2010 3:09 PM
To: fusion-users; fusion-dev at lists.osgeo.org
Subject: [fusion-users] v2.0.0 release candidate available
I'm pleased to announce that the first release candidate of Fusion 2.0.0
is now available
(http://download.osgeo.org/fusion/fusion-2.0.0-RC1.zip).  Release notes
and more information are available on the Fusion download page
(http://trac.osgeo.org/fusion/wiki/GetIt).
Please try it out and if there are no major issues uncovered in the next
week, we will then proceed with the final release.
Regards,
Mike
   Michael Adair
   Senior Software Architect
   DM Solutions Group Inc.
   Office: (613) 565-5056 x26
   madair at dmsolutions.ca
   http://www.dmsolutions.ca
   http://research.dmsolutions.ca
fusion-users mailing list
fusion-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fusion-users
Important notice to recipients:
Copies of documents that may be relied upon by you are limited to the printed copies (also known as 'hard copies') that are signed and sealed by the Engineer and/or Land Surveyor. Files in electronic formats, or other types of information furnished by the Engineer and/or Land Surveyor to you such as text, data or graphics are for your convenience only. Any conclusions or information obtained or derived from such electronic files will be at the user's sole risk. When transferring documents in electronic formats, the Engineer and/or Land Surveyor makes no representation as to long-term compatibility, usability, or readability of the documents resulting from the use of software application packages, operating systems or computer hardware differing from those used by McMahon Associates, Inc. at the beginning of the project.
More information about the fusion-users mailing list
