[fusion-users] v2.0.0 release candidate available
Mike Adair madair at dmsolutions.ca
Thu Mar 25 15:57:32 EDT 2010
Can you open a ticket please?  It would also help if you can attach you
AppDef with the Maps that cause the problem.
Mike
Berdel, Brian wrote:
> I still see the Legend issues I posted yesterday (see below), which I think are a major issue. I didn't receive a response so I am not sure if it is just me or not...But I am using the standard templates and sample data.  IE7 IE8 and FireFox 3.6.
> I can open a ticket, but I wanted to check if anyone else has experienced this.  I searched and did not find anything.
> I am getting a couple error in the SVN version using Sheboygan data / standard templates or my own templates.  When opening the Map with Two Maps (Using one as a base map)  I get 'LegendLabel' is null or not an object in legend.js (Line 9 in createTreeItem) and the variable style is coming in as null.
> 1 createTreeItem: function(layer, style, scale, bCheckBox) {
> 2        var opt = {};
> 3        opt.statusIsDefault = layer.statusDefault;
> 4
> 5        if (bCheckBox ) {
> 6            opt.label = layer.legendLabel == '' ? ' ' : layer.legendLabel;
> 7            opt.draw = this.renderItemCheckBox;
> 8        } else {
> 9            opt.label = style.legendLabel == '' ? ' ' : style.legendLabel;
>             opt.draw = this.renderItem;
> The Base map is also displayed on open even though I have the layer set to off and the check box for the layer is also not checked.   So I have to check it and then uncheck to turn it off.
> Also the following occurs with one or two maps.
> Clicking on the map name check box also throws an error, and it turns off but not back on...
> Line: 1038 of Mapguide.js
> Error: 'this.oLayerOL2' is null or not an object
> Thanks,
> Brian
> -----Original Message-----
> From: fusion-users-bounces at lists.osgeo.org [mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of Mike Adair
> Sent: Thursday, March 25, 2010 3:09 PM
> To: fusion-users; fusion-dev at lists.osgeo.org
> Subject: [fusion-users] v2.0.0 release candidate available
> I'm pleased to announce that the first release candidate of Fusion 2.0.0
> is now available
> (http://download.osgeo.org/fusion/fusion-2.0.0-RC1.zip).  Release notes
> and more information are available on the Fusion download page
> (http://trac.osgeo.org/fusion/wiki/GetIt).
> Please try it out and if there are no major issues uncovered in the next
> week, we will then proceed with the final release.
> Regards,
> Mike
>    Michael Adair
>    Senior Software Architect
>    DM Solutions Group Inc.
>    Office: (613) 565-5056 x26
>    http://www.dmsolutions.ca
>    http://research.dmsolutions.ca
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
> Important notice to recipients:
> Copies of documents that may be relied upon by you are limited to the printed copies (also known as 'hard copies') that are signed and sealed by the Engineer and/or Land Surveyor. Files in electronic formats, or other types of information furnished by the Engineer and/or Land Surveyor to you such as text, data or graphics are for your convenience only. Any conclusions or information obtained or derived from such electronic files will be at the user's sole risk. When transferring documents in electronic formats, the Engineer and/or Land Surveyor makes no representation as to long-term compatibility, usability, or readability of the documents resulting from the use of software application packages, operating systems or computer hardware differing from those used by McMahon Associates, Inc. at the beginning of the project.
   Michael Adair
More information about the fusion-users mailing list
