[fusion-users] Re: No properties shown in selection
gnoviello grazia.noviello at libero.it
Fri Nov 19 06:31:36 EST 2010
Il 18/11/2010 23:40, zspitzer [via OSGeo.org] ha scritto:
> can you submit a patch to trac?
> On Thu, Nov 18, 2010 at 11:25 PM, gnoviello <[hidden email]
> </user/SendEmail.jtp?type=node&node=5753601&i=0>> wrote:
> > I found the solution in GetPropertiesSelected.php file.
> > At load map time, in the LoadMap.php file, an array of properties of
> the
> > existing layers is stored in a session variable "property_mapping".
> In the
> > GetPropertiesSelected.php file, that reads the properties of
> selected item
> > on map, this array of properties is read.
> > I've inserted a new layer in map after the map is loaded, so when I
> > requested the selected object on this new layer, for this layer
> there wasn't
> > an entry in the session array "property_mapping".
> > So for my new layer no properties was requested to the service.
> > Now I've modified the GetSelectedProperties.php file to read, if there
> > aren't, the properties list of new layer.
> > It works.
> > Thanks,
> > Grazia
> > View this message in context:
> http://osgeo-org.1803224.n2.nabble.com/No-properties-shown-in-selection-tp5750730p5751435.html
> <http://osgeo-org.1803224.n2.nabble.com/No-properties-shown-in-selection-tp5750730p5751435.html?by-user=t>
> > Sent from the Fusion Users mailing list archive at Nabble.com.
> > fusion-users mailing list
> > [hidden email] </user/SendEmail.jtp?type=node&node=5753601&i=1>
> > http://lists.osgeo.org/mailman/listinfo/fusion-users
> Hi Zac,
of course yes.
I prepare the envoirnment and submit it.
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au <http://www.ennoble.com.au?by-user=t>
> http://zacster.blogspot.com <http://zacster.blogspot.com?by-user=t>
> +61 405 847 168
> [hidden email] </user/SendEmail.jtp?type=node&node=5753601&i=2>
> View message @
> http://osgeo-org.1803224.n2.nabble.com/No-properties-shown-in-selection-tp5750730p5753601.html
> To unsubscribe from No properties shown in selection, click here
> <http://osgeo-org.1803224.n2.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5750730&code=Z3JhemlhLm5vdmllbGxvQGxpYmVyby5pdHw1NzUwNzMwfC05MjQyNTUxODQ=>.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/No-properties-shown-in-selection-tp5750730p5754917.html
More information about the fusion-users mailing list
