[fusion-users] Fusion Search - Error when there is no results.
kelll kellieharrisson at sierrasystems.com
Wed Nov 24 18:41:31 EST 2010
Hi there,
I am trying to implement the fusion search widget. Im using fusion version
2.0.0 with Mapguide OS 2.1.
My mapguide is within an iFrame.
Here is my search widget settings in ApplicationDefinition.xml:
  toolbarSearch
  Search.
  images/icons/search.png
        Hello
        50
                c1DisplayId
                c2LocationDescription
        DisplayId LIKE '%$USER_VARIABLE%'
When I activate this widget, it pops open in a window with a search prompt
(as expected).
1. If I search for something that I know will have 0 results, it pops up a
javascript error ( 'mapName' is undefined ) which I have traced to the
ErrorPage.templ.
I added the mapName variable at line 31 so that the page could find mapName:
var popup = %s;
var mapName = "%s";
I also edited the OnError event in Search.php to be:
function OnError($title, $msg)
    global $target, $popup, $mapName;
    $templ = file_get_contents("./ErrorPage.templ");
    print sprintf($templ, $popup, $mapName, $title, $msg);
Doing this stops the error, but then I get more errors.. I try to keep
resolving these errors, but they keep coming... is the ErrorPage.templ
trustworthy or is the problem between the chair and the keyboard? :)
2. Also, is there a way to have two clauses in the search filter?
DisplayId LIKE '%blah%' OR LocationDescription LIKE '%blah%'
Thanks in advance,
Kellie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Fusion-Search-Error-when-there-is-no-results-tp5772524p5772524.html
Sent from the Fusion Users mailing list archive at Nabble.com.
More information about the fusion-users mailing list
