[fusion-users] Changing the Fusion template dialog chrome
frosty1_4me kbowman at cityofgp.com
Mon Oct 25 18:55:51 EDT 2010
I've noticed that the fusion template I'm using (aqua) when changing the
dialog boxes to be resizable, introduces an odd result.  If you resize the
panel vertically, the panel looks correct.  However, if you resize the panel
horizontally, the img used in the jx.chrome doesn't extend but will repeat
so as a result you will see more than one panel image if you resize your
content beyond the extents of the image used.  (in this case 500px x 500px).
It doesn't seem to matter vertically and if you resize the panel beyond what
should be 500px, the panel still looks correct.  Does anyone know how to
correct this problem in the jxtheme.css file?  (approx line 1131 is where
the dialog style is defined)
Thanks.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Changing-the-Fusion-template-dialog-chrome-tp5672758p5672758.html
Sent from the Fusion Users mailing list archive at Nabble.com.
More information about the fusion-users mailing list
